Team Losi JRXS
#1681
#1682
Re: new site
Originally posted by bgolat
please check out and register at www.jrx-s.com
#1683
good to know, i didnt know it wasnt sending them out...ill check into that.
#1685
Thanks Bill, again..
I guess it's just a lack of imagination if we cannot find a suitable place for those connectors.
Has anyone seen a picture from Brian's spur gear adapter that has a view from other side of the car than this one picture from Novak Race which was posted earlier?
#1686
not yet copter. Im thinking of going out to the local track where he practices, and see if I can't get a snap shot, and more video.
#1687
Connector issiue?
Just build your packs like that!
#1688
Another one.
#1689
Come to think of it, those corally connectors won't work the way they are intended to. Since the hole in the chassis is nearly as wide as the battery pack, the connectors won't be able to pass through that hole.
But someone mentioned laying the connector horizontaly between the cells at each end of the battery pack. That would work, just need a regular battery bar to jump from the connector to the cell terminal. Kinda complex, but maybe ideal.
EDIT: A picture is worth a thousand words, see posts above and below!
#1690
Last one!
#1692
nice fastfreddy.
#1693
As you can see connectors are flat under the cells, and barely touch the bar......
#1694
The only other thing i would do is add a little insulation under each plug. Just to help prevent shorting.
#1695
