tire baking
tire baking
a while back i asked on here how to get a tire off a rim. well, today i have to revise that question. how do i get a rim off a tire?
i have a set of losi directionals that i love up front, but im switching to velocity rims for simplicities sake. how do i get the tire off the stoopid wheel without damaging the tire?
i know baking dries up the glue, but A)will it work for rubber black CA, and B) will it damage the tire?
I have a freind who has done this (LosiFromHell), it dosnt damage the tires at all, and im prytty sure it works on tire CA
I hear that you can use acetone to get them off.... but I'd ask someone else before you try that.
Sory, I thought he had stated that he was boiling them but I missread, do not BAKE your tires, youll fry um
Boy am I confused. One person says don't bake them. Another says bake them. Boil them, use acetone, or whatever.
I personally have tried all these methods, and am happiest with baking them. Boiling doesn't work for me, and acetone usually ruins both the tire and rim.
However, I have had great success with baking. I put them in my toaster oven at 350 for 10-15 minutes, and the tires come right off. You may have to remove some of the excess glue but the tire will be just fine. The foam will need to be replaced, but they only cost a few dollars. I have a set of tires I did this to several months ago and they still work perfectly.
Give it a try and see what happens.
BY THE WAY, YOU WILL NOT FRY THE TIRES NO MATTER WHAT ANYBODY SAYS.!!!!!:-)
lol dually noted
well i ask because i had RPM clawz on my car with 1/4" axles, and proline dirt hawgs. the dirt hawgs are my favorite bashing tire of all time.
now, im switching to 3/16ths CVDs this week, and i got new rims with fuzzies on them, and new front rims to match (dish rims) with losi edges.
my goal is to get the losi edges off my OLD claw rims so i have spares, and id like to get my dirt hawgs off so i can mount them to 3/16 dish rims and switch tires between home and the track.
the dirt hawgs have almost no wear on them and its a shame to throw away perfectly good tires. the bad news is i used black rubberized CA to glue up the clawz rims, so im not sure if the black CA will react to baking the same as regular CA.
i run the dirt hawgs with no foam anyway, they grip like pissed off mofos on gravel and pavement
Beetlebz,Soak your tires in some acetone over night.this won't hurt your rim or tires it works great. --------------------------------------------------------------------------------- losi XXX-NT os 12 tr rear exuast engine trinty 5 cell R/R hard anodized monster diffgraphite lunsford titanium buckles drake pipe steps and razor ribs gettin a ambit transponder
But it will kill the foams.
i dont care about the foams, and i dont care about the rims.
and im not opposed to buying new tires and dishes to go with them, but id just hate to toss a perfectly good set of tires because theyre attached to rims i no longer need
Lets see now, rims don't matter to you. And you don't use foams. So all you want to do is remove the tires from the rims. Based on my experience, I still say the best method would be to bake them. Acetone would work as well in this case. Try baking first and if that doesn't work, then try the acetone. At the worst all you are out is a set of tires, which you can't use right now anyway. Good luck, and I hope it all works out for you.
I wouldnt bake my tires ive used acetone several times and my rims an tires arent screwed up.
I've tried acetone and freezing also. Freezing makes the tires very stiff and hard to work with, and the glue doesn't come off for me. Acetone won't work well either, maybe if you had some pure stuff, but i used acetone nail polish remover in a syringe with a small tip.
I haven't tried baking because boiling works perfectly for me..
OK, regarding acetone....
Nail polish remover is not the same thing as concentrated acetone - not to mention the fact that I have never seen a gallon of nail polish remover sold as such...
Acetone will save the rims to re-use, but in many cases it will "change" the compound of the tire (i.e. making the tire feel harder than initially.) Acetone will NOT work on all rims - in many cases it will destroy the rims - Yokomo rims some to mind - but it will work just fine on Losi and AE off road rims. Acetone also requires the use of a heavily ventilated area (read OUTSIDE) as the fumes are quite toxic - not to mention quite flammable. The tires will need to sit in the acetone overnight for best results
The bottom line is that if you are looking to save your tires, don't use acetone. Both baking and boiling are good alternatives, but may not work on all glues.
I understand about the acetone, but some people at my track said nail polish remover would. I actually removed a tire with it, didnt really damage the rim or tire, but it left little chunks of rubber from the bead on the rim..nothing too bad though. It took forever though.
