Team Br00d Racing Motors
#2686
Identifying motors?
Hi!
Got 2 Co27 stocks from Br00d thanks!
One tuned for carpet and other for asphalt, but I can't indentify witch is for carpet and for asphalt one.
One motor has both red springs and another purple for "+" and red for "-" .
Or is there any difference where to use them?
WBR,
WBR,
#2687
I cant wait to try the new br00d power... schould be here in a few days
Thanks EddieO!
-Hugo
Thanks EddieO!
-Hugo
#2688
Harg, Red/Red is asphalt, purple/red is carpet...
Scho, none at this time.....its possible we may get some in the next 10 days or so, but no guarantees.
Later EddieO
Later EddieO
#2689
EddieO do you have the intergy lathe in stock?
-Hugo
-Hugo
#2691
shirt
Eddieo
can you take a XL longsleeve shirt to the carpet nats? would like to get one will pay you when i get there.
Larry
Larry
#2693
Eddie, I guess my emails haven't been getting through so I sent a PM. I'm assuming you've cleaned out your PM box...
#2694
just trying to check the status of my order #1142. thanx a lot.
#2695
eddieO you have a email
#2696
I guess PMs aren't working either...
Eddie, I got those motors in the mail the other day.
#2698
hi on the 8t ti worlds i got, there is a silver shim and a rubber o-ring on the commutator end. i lost the o-ring. what is the purpose of this o-ring? can i just add more silver shim and not use the rubber o-ring?
or can i use some Phenolic Washers?
also with shimming the motor, how much freeplay shoudl you allow for?
cheers
cheers
#2699
The o-ring reduces vibration, although it isn't necessary. You can just use shims to shim the arm.
As far as freeplay, just go by feel. You don't want the arm to be tight, you just want a very small amount of movement. About .010" play - the difference a small brass washer makes. A little less is preferable to a little more than .010".
Josh
Josh
#2700
