Team Br00d Racing Motors
#2176
Rookie Question
Thanks Eddie....should have asked before buying. I will call before my next order. Thanks again.
#2177
Eddie what atlas stock is better the laydown or the angled brushed one? Also are they more of a torque or rpm based?
#2179
They are in between a monster and p2k2 RPM/torque wise....
The angled brush stuff is cool.....we have not done enough testing with them to see if its better than the non-angled one....
Later EddieO
Later EddieO
#2181
It sorta is.....I will try to get better pics up by friday.....
Later EddieO
Later EddieO
#2183
Well.....a Ti one will fit, but I will not warranty it....the V2 stuff is to risky to run them in, because if the armature shifts in a bad crash, the Powertrix will hit the brush tubes and explode.....
So, if you want one that bad....a Ti one will work and be 100% legal.....however, its use at your own risk.......I can easily tell if a v2 blew it up....
They are stupid fast in V2s too.....
Later EddieO
Later EddieO
#2184
Hello EddiO,
The center cut armatures you have for the V2 motors are they the 4mm or 5mm Web??
I am about to order one to test and need to know what wind I should order.
10x1 w/4mm web is what I would like to try!!
Thanks!!
Thanks!!
#2186
XX4 Mod Motor
I will be running a XX4 with a mod motor. What mod motor would you recommend? The track is 100 x 60? Theya re putting an oval around the outside so the infield will be tight.
Thanks,
David
Thanks,
David
#2187
David you really cant go wrong with any of the reedy mods, Kr ,Ti, Ti worlds as well as the trinity cobalt. all great motors. if its going to be a tight infield i would go with a tripple wind. either 12x3 or 13x3.
this is all of course my 2cents... each track will be a bit different. if its extremely smooth track a lower wind maybe nice. but you can also try some doubles too.
#2189
EddieO, YGPM
