Ask Steve "The Evicerator" Weiss
#4096
That's the noise he makes when he has to answer countless questions from newbz
#4097
hey scuba thanks for the springs ill give them back to you at socal
#4098
Great job on your win Jason. You definately earned it. As for me, Vegas was the best time I had losing an rc car race ever!
#4099
THANKS ROD GLAD YOU HAD FUN SEE YOU AROUND SOON IM SURE
#4100
Question:
Using a new motor dyno, it tells me the amp draw and the rpm's. I'm dyno'ing at 5volts and unsure if the higher the draw amp the better the tune/motor?
I changed to cavity style brushes and the draw is approx 7amps then put a red spring on the positive side and the draw came up to 7.5amps.
Got some tips or advise on what I should be doing to make the best rpm's and torque?
#4101
Hi Guys, open question to anyone who can help.
Running a FT TC4 with checkpoint 9X1 and really good batteries and keep spinning the tires off the rims purely due to the power. Any suggestions on a fix???
#4102
The Evicerator
Barry--
Dyno's are good tools to have... but the best test for a motor is ALWAYS on the track.
What good is a dyno result number if it doesn't help yeild good lap times or the motor only runs that way for 30 seconds on the track?
I would use the dyno to see what sort of things do what as far as pulling current, what produces rpm...all so you can try them out on the track and see what actually works best for you out on the track.
Then, once you have a good basline motor setup you can use the dyno to track the motor's performance over time or to compare differnet motors with simlilar setups to find your "best" motor.
Speedbug--
This might sound a bit simplistic...but just make sure your tires are glued well... we run 7-turn speed motors all the time and keep the tires on the rims....
Some steps you can take: clean the inside bead of the tire and the rim with motor spray or rubbing alcohol. Next, use a high quality CA glue... Losi blue or red generally get the trick done
Speedbug--
#4103
Thanks i'll try the alcohol. Is it worth scuffing the surfaces with sand paper or something before glueing?
#4106
The Evicerator
Space Cake?
#4109
The Evicerator
So who's running where this weekend?
#4110
None for me this weekend, need to take a break for a week or two.
