Picco engines ?
Picco engines ?
are these engines good are they beter than mt12 dose any one have one? planin on upgradin my ntc3 and dont know what to put in thankyou
Picco's are ok... I have a modified 7 port that put's out very good power.. What picco motor do you plan on buying??? The MT12 has been out for almost 3 years now and is now considered very old... If you want power and want to race your NTC3... I would consider buying a Novarossi based NS motor... The RS line of motors are old as well. Also consider the pipe you have to use with your NTC3... The dual chamber pipe is a short pipe. Which motor will run best with that pipe??? I know that my 7 port runs better with a long pipe... You can't go wrong with a Top TS3, RB V-12 or Novarossi NS3, with the type of pipe you're running on that car.. Hope the info helps..
RC_Alan
RC_Alan
