Kyosho v-one rrr
#1381
Originally posted by Team-RTR
i had extreme amounts of trouble with my RRR tank. at the summernats my engine would overheat something silly on the track, but in the pits it was running at a consistent 85-90 degrees celcius. i wasnt sure what was causing it but i now realise that the tank leakage was leaning out the engine like crazy.
You go out and do the warm up and come into the pits and you just can't stop the car idling up. Richen it up the smallest amount and the car just won't pull.
I ran the final at Moorebank last weekend and won but it was running very hot and would really struggle to run five minutes on a tank, while others made six minutes.
I came home tested the tank and the tank lid may as well not have been there.
#1382
Originally posted by Craig1
This decribes one of the problems I had at the Vic's and at the last club day at Moorebank.
#1383
yeah, at summernats i could only manage about 4 minutes 45 per tank before runnin out of gas. and yeah the engine idles up like crazy wen you pull it into the pits. at summernats i brang it in twice in my final to richen it slighty and the engine was stilll overheating.
Submerge the tank in some water and blow through the pressure line.
My guess is you won't have to try too hard to make some lovely bubbles come out from under the lid.
#1384
jeffery, which is this new upper deck you speak of? is it the same part number as the old one or is it a new part number? also could you please post a pic? thanks!
#1385
Thanks guys. I didn't think of the Japan site.
#1386
Originally posted by jeffreylin
VZ230B. Picture shows new vs. old
#1388
Originally posted by JordanC
It looks like only one end has an elongated mounting hole?? I haven't had any problems with my tank at all and i've been running it now for about 8 litres. I also haven't had any drama's with the stock exhaust mount.
#1389
Originally posted by Marcos.J
Hey Jeffrey good luck at the "NAT'S"
#1391
Originally posted by Sow&Steady
Let's get specific NiMo, this is the RRR forum, BELT drive, not the FW05 forum or a shaft-drive forum ... shoo shooo ... what are you doing here I thought you DON'T have a RRR? I on the other hand DO have one, albeit not mine!
Good excuse I think
And as I've stated in an earlier post, I don't run an RRR, but I am running Kyosho
#1392
RRR Worlds?
Hey guys, I heard that in Japan there is a rrr worlds kit. Do you guys know the difference between the rrr and this kit?
#1393
Re: RRR Worlds?
#1394
Super Moderator
Re: RRR Worlds?
http://www.kyosho.co.jp/web/products..._rrr_wc-j.html
here is the picture!
#1395
Thanks for the link Marcos J.
