Kyosho v-one rrr
#9316
alright, thanks for the info. im just curious, i probably wont do it since i just got my V-1 RRR as my first nitro car a few days ago, and im an absolute NOOB (WHAT THE HECK IS A PORT?)
Oh, and since you are a Kyosho team driver, might you know Mike Ellis? He is another Kyosho sponsored driver that lives in my area.
#9317
OK sure on Hightracion Traks the new Compo will be better but here in Switzerland we have a lot of lowtraction Tracks so I can`t anwser that
But test the TF-5 Shocks guys the diverent is so big. Dont forget everybody has his own drivingstyle so test it an then you know whats the best for you.
greetz
greetz
#9318
Rear Upper Arm
I have now downloaded quite a few Team driver setup sheets and notice that almost all the team drivers set the rear Upper Arm Height at 0mm in the "IN" position. Now I understand that this makes the upper arm (camber link) longer and slightly less angled (compared to when you use the 2mm spacer) and that this will give more chassis roll and thus more grip in the rear. My question is, and I intend to try this on Sunday (race day ) anyway, does this give more rear grip onpower or offpower?
#9319
• More on-throttle grip.
• More weight transfer at rear of car.
• Less grip under braking.
• Use to avoid traction rolling at corner entry (increases rear grip).
• Use under low traction conditions.
• Increases traction, reduces rear tire wear.
#9320
Great ...thanks for the response!! This is exactly what I have been waiting to hear. My car has phenomenal front grip ...so much that the rear feels light offpower and is slightly lose under power. I have been battling this since I got the car about six months ago and have tried different springs and shock positions to no avail. At the last club race I got desperate and used 40 shore fronts and 35 shore rears! This helped BIG time but the faster rear tire wear absolutely killed the balance of the car even before reaching the halfway mark in the qualifiers!!
Seems I need to back to the stock setup and then try the new new upper link position.
#9321
#9322
#9323
hi....
1.basically what effect will one be having when changing the rear shock position?
2.i am running a new set up just to see how, and i like it except i'm feeling understeer at corner entry/ or the rear is too planted? i need a little bit more loose rear and it would be almost perfect...corner exit is ok..
thanks.
thanks.
#9324
Originally Posted by rcabj
hi....
thanks.
thanks.
All these changes to the rear affecting the rear grip:
- Hrear tyre than front
- Higher rear shock position
- Harder rear spring
- Less rear TOE-IN
- Less rear droop
Remember to make 1 change at a time
Hope this help you
Regards,
Nick
#9325
Originally Posted by nikoskar
If you change the rear shock position to the bottom is like you have a lighter spring.You earn more rear grip.
Hope this help you
Regards,
Nick
- Less rear TOE-IN
- Less rear droop
Hope this help you
Regards,
Nick
#9327
Do you guys usually go with the collet that comes with the kit or the collet that comes with the engine?
#9328
Originally Posted by Krafcik
Ok, I'm ready to pick up a V-One Evo WC RRR . . . . which on-line retailer has it the cheapest?
Thanks.
Thanks.
Plus you get free & quick UPS shipping.
#9329
Thanks.
Thanks.
Check this out
http://www.rctech.net/forum/showthread.php?t=163283
#9330
KAWAHARA RACING PRODUCTS
Does anyone know where i can buy on line Kawahara products for v-one rrr ?
I'm basically interested for the K472 and the K497.Here are the pics?
