Kyosho v-one rrr >
Kyosho v-one rrr
Kyosho v-one rrr
Old 03-10-2007, 07:26 PM
  #8986
Originally Posted by rmdhawaii
Unfortunately, it's not set and forget. You constantly have to adjust your engine settings based on humidity, temperature and air pressure. As soon as the engine doesn't run right, you need to put your thinking cap on and retune it.
In the same day, just after it cooled down for a bit that is what happened. Usually I set it and basically just leave it. Only a few minor tweaks here or there based on the performance of the engine each day.
btw: the thrust bearing has a certain direction it should face. I took it out and now totally forgot to look at the direction it was...so I left it out until I find how it goes. The Manual isn't very clear...which way to pit it in? There's a recessed side and a side that looks like the balls make contact with the surface it's facing. Last time I noted the direction it was before taking it out to grease it up, this time I just totally forgot...
Dredd is offline
Old 03-11-2007, 03:33 PM
  #8987
just a little bump.
any help on the direction of the thrust bearing? which way should I install it?
Dredd is offline
Old 03-11-2007, 03:46 PM
  #8988
Trader Rating: 15 (94%+)
i always install mine with the faceof the shield pointing out..
just seams like less dirt can get in to the balls
mrgsr is online now
Old 03-11-2007, 03:56 PM
  #8989
Nosram's Avatar
If you mount it the other way, then there is more chance for any dirt ingress to find its way out of the bearing area
Nosram is offline
Old 03-11-2007, 04:06 PM
  #8990
So the recessed part is pointing toward the clutch bell?
Dredd is offline
Old 03-11-2007, 05:44 PM
  #8991
rcabj's Avatar
Originally Posted by Dredd
just a little bump.
previously i just install those 3 pieces thrust bearing whicever way i like (as long as the bearing r in the middle)...but after carefully reading the manual u will notice that the 2 washers that 'sandwich' the thrust bearing has 2 different sizes..if i am not mistaken the smaller internal diameter goes inside (please correct me ), as for the bearing itself i do not think putting it whicever side will effect the mechanical functions....just like u guys said maybe less or more dirt..
rcabj is offline
Old 03-11-2007, 10:52 PM
  #8992
MRX4-R03's Avatar
Didn't this thing come with any instructions??
I don't have this swayblade, but I do have the Kawahara version. Put the car up on a car stand, remove the shocks and adjust the ball links so that when you turn the blades 90 degress, it isn't touching the brake bracket. 1.0 mm clearance should be sufficient.
After you've made the adjustment, put the shocks back on and make sure that the blue piece isn't touching the belt. If it is, let us know.
Ok well after running my car this week, the blue connecting point is touching the belt, do you know if the evo upper plat is different from the regular wc, I need to look at a evo this week a friend of mine has one I will see if they are different!
MRX4-R03 is offline
Old 03-12-2007, 12:27 AM
  #8993
rmdhawaii's Avatar
Too bad. It probably means you have the original part and not the revised one. Contact Kyosho and see if they will replace it for you.
rmdhawaii is offline
Old 03-12-2007, 12:57 AM
  #8994
Chemical X's Avatar
Trader Rating: 18 (100%+)
I'm still building my new RRR Evo WC and I noticed that the belt is hitting the rear sway bar assembly too.
Rainer, what's the difference in the parts you are referring to?
Chemical X is offline
Old 03-12-2007, 01:40 AM
  #8995
rmdhawaii's Avatar
Below is a picture of the Kawahara sway blade. Notice the notch on the bottom?
A guy at our track also had this problem with his Evo WCE and it tore up his belt. He just ground down the part down until he had enough clearance.
I'm really surprised this is still an issue. As I understand it, Kyosho already has an updated version of this part.
Old 03-12-2007, 02:58 AM
  #8996
johnypiston's Avatar
Default Results ...
Just in the way of feedback ...I did much better than expected considering I hardly had any brakes and the top 4 drivers in the country were in attendance. Believe it or not, I still had enough speed to win 2 out of my three qualifying rounds and managed to qualify SIXTH IN THE A-MAIN!! This was only my second ever race and apart from softer rear springs and oil, the car has stock settings. My aim was simply to do better than last time ...I shocked myself really. Now I can take the car and start adjusting for better handling. The aforementioned top four are doing laps in the 19s ...my quickest for the day was 20.02 and I had an average in the 20s ...my feeling is that I could easily gain half a second just with the addition of a spool or even front diff. With one of those items I'd be able to take more speed into the corners ...something I could not do yesterday.
Anyway, we are having a national meet from the 11th of April and based on my performance yesterday, I reckon I'll give it a shot. A top ten placing no longer looks out of the question.
Oh, and by the way, the biggest thing for me is that I brought the car back in one piece ...no major crashes!! As for the A-final, I ended up 7th out of ten ...basically I stripped a gear with only 4 minutes left to the end of the race ...at that stage I was 5th!!
Again thanks for the input guys ...the car is awesome ...not at it's best yet but awesome. I displaced some experienced guys yesterday and I am over the moon about the fact that they were shafted not only by a newbie ...but a newbie with the ONLY V-One RRR on the track ....HA
johnypiston is offline
Old 03-12-2007, 07:36 AM
  #8997
Ivan Dickson's Avatar
Trader Rating: 32 (94%+)
Thumbs up
Congrats on a great day at the races good to see RRR owners do well RRR is just a great car to drive.
Ivan Dickson is offline
Old 03-12-2007, 07:46 AM
  #8998
nitro_moe's Avatar
Definetely go with spool.. Forget about front diff because it could slow you down more than give you more speed at the corners. Unless you are running on a short and very technical track, the front diff could be the way to go.
Anyways, good luck on your next race and keep up the good driving..
nitro_moe is offline
Old 03-12-2007, 08:33 AM
  #8999
Wink Race Results
Had a geat weekend at the races car handle great no problems ran the new kfactory tires which were good the whole day considering 90+ heat we just finish up a 4 race point series were I finish first very good compitetion in novice class also I am offically moving up to amateur level which I feel I'm ready to do Can't wait to the next race which will be in 2 weeks Airtronics Championship a 3 day race to view on road race series results click on my link Revelation at the bottom of my signature go to on road.
Old 03-12-2007, 11:58 AM
  #9000
MRX4-R03's Avatar
I just got off the phone with Kyosho and they told me they are not aware of this issue and there is no revised part yet out, any ideas on what I should do..
MRX4-R03 is offline
