Kyosho v-one rrr
#8657
Originally Posted by mrgsr
rainer do these collets fit the tz and kyosho flywheel better?
what i do is get the standard collet and grind it down on a file till i get the correct gap between the engine and flywheel.
Grinding it down sounds like a pretty good idea. Are you doing anything special to ensure that it's straight? i.e. using oil, rotating it every two-strokes, etc.
#8659
Originally Posted by rmdhawaii
I have no idea if they fit, but at $2 a piece, I have nothing to lose.
Thanks for the parts. Let me know what I owe you.
#8660
#8661
Originally Posted by jag
You might as well just send them to me. If the OS is like all the rest, they won't fit. The Mega/Picco crank is a little smaller in diameter.
#8662
If it doesn't fit, they are yours - gratis.
#8663
Would it be wrong of me to hope they don't fit?
If it doesn't fit, I'll grind the ones I have instead.
#8664
Hey,
I am having difficulties in adjusting the end play and the clutch gap too. Could anyone explain why we should leave .5mm at step 43 and why should we keep adding shims at the endplay? What happens when the endplay is too loose? I am not sure if I am making too much sense, but this is my first nitro car >< I am very noob at it ><
#8665
Originally Posted by kmaheartless
Hey,
The gap is permitted distance of the clutch shoe and is preventing the deadlock from metal expand. it needs to coordinate with the strength of the clutch spring. By adding the shims at the endplay, the clutch gap will be decreased and that is the setting of the clutch.
0.5mm is the default setting.
Hope this could help..
#8666
Originally Posted by tony montana
here are some pics of the space I was talking about with the flywheel and engine bearing space. Some body help please
If you are using the OS collet you may want to try the Kyosho one & for those that are setting up extra clutches the Kyosho collet & spacer # is um213 they cost about 5 or 6 bucks @ the local hobby shop
#8667
Hey,
#8668
Hello!
Thanks Gmartinez and kennyee! Your explanation helped alot! I am also wondering if it is possible to use the 5 x 10 shim instead of the suggested 5 x 7 shim on the www.nitrokb.com. Can I mix them together? Also, how do I adjust the setting of the 2 speed changer?
#8669
The two speed is adjusted by the two screws that hold the two speed shoes together. The tighter you make the screws the later the cars shifts. Loosening them does just the opposite and makes the car shift sooner. Hope this helps.
Eric
Eric
#8670
Hey all, I am eagerly awaiting the arrival of my kit and have a question. What pipe do I need for it and do I also need a header? I am putting a Novarossi NS-12 in it.
Please give info on where to get also.
Thanks for any suggestions.
