Kyosho v-one rrr >
Kyosho v-one rrr
Kyosho v-one rrr
Old 06-08-2006, 02:05 AM
  #7231
rmdhawaii's Avatar
Originally Posted by rayjay
Cheers all for your help. However...im very new to all these adjustments.. Ive just come from a rs4 that didnt have many things to adjust.. couple more q's if i could.... How do i adjust the droop.... u said track width.. where do i measure this distance from.....rear sway bar soft like 1.8 or softer ???????? does anyone have a "Setting Data Sheet" they could e-mail me.. Thanks again for all your help... I will start doing all that other stuff now and i will see how i go.
Setting data sheet is here:
http://www.kyosho.co.jp/web/download...rr_basic_e.pdf
Go to the web site listed below and download the Hudy Set-up Book. It will explain how to measure and make all the adjustments.
http://www.teamxray.com/teamxray/pro...81&kategoria=0
rmdhawaii is offline
Old 06-08-2006, 07:59 AM
  #7232
maskedrider's Avatar
Guys, I'm going to stop running for at least two month....
wht your best recommend for maintaining the engine ??? :
but........
reason : my wife is giving birth soon
maskedrider is offline
Old 06-08-2006, 09:07 AM
  #7233
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Some go as far as taking the motor completely apart and submerging the internals in motor oil.
I think thats kinda far beyond needed. If anything make sure the gas-tank is completely empty - run it on the starter box with the glow-ignitor attached to run out any extra fuel after your run.
Then run some after-run oil through it and leave the glow-plug off so air can get in there....should be good. Also taking the pipe off would have around the same effect , allowing the moisture to leave....
Artificial-I is offline
Old 06-08-2006, 09:11 AM
  #7234
litespeed-dom's Avatar
but........
Well, first congrats on the newborn!
If I need to put the motor aside for prolong duration and this is just me... I take the motor apart, clean and oil everything that needs to be oiled, and put every seperate part in its own small ziplog bags.
Dom
litespeed-dom is offline
Old 06-08-2006, 09:19 AM
  #7235
rmdhawaii's Avatar
but........
Congrats! Is this your first one? If so, I wouldn't be so quick to put the engine away.
Old 06-08-2006, 12:24 PM
  #7236
robert maestrey's Avatar
Dom
same hear zip-lock bag and lubricate entire inside contents of bag......also pretty important also vacum seal the bag try and get all the air out of bag when sealing it.
robert maestrey is offline
Old 06-08-2006, 12:26 PM
  #7237
but........
Congratz man hey make sure you throw an old controller of yours in that crib. never know you might have next world champ
Old 06-08-2006, 05:41 PM
  #7238
jag
jag's Avatar
Originally Posted by NismoSkyline17
How do you guys like the Kyosho tires? How do they handle and how does the wheel hold up?
I have tried the Kyosho tires and they are pretty good. I compared them to Jaco's and found the Jaco's to be a little better in the traction department but the Kyosho wheels are more durable. If you switch your rear universals (VSW007) to use 0 offset wheels I would recommend trying the Serpent/Jaco tires. They provide excellent traction and durability.
I do think that the Kyosho wheels are the best looking wheels out there but they are also among the most expensive.
jag is offline
Old 06-08-2006, 05:45 PM
  #7239
jag
jag's Avatar
but........
Congrats on the child. For the engine storage, I do as Robert and Dom and take it apart, clean it, lube it up and put it away. I usually put it back together before I store it but I do put it in a zip-lock bag and cover the carb and exhaust.
jag is offline
Old 06-08-2006, 05:50 PM
  #7240
jag
jag's Avatar
Originally Posted by Paolo M
Define "those people"
Paolo
Apparently "those people" are not Serpent USA. I am curious who is saying that. I race with Robert some and he has not mentioned anything to me about this.
jag is offline
Old 06-08-2006, 11:41 PM
  #7241
thanks All for all the blessing and tips.......
gonna to miss some club race and major event race...... but
I WILL BE BACK !!
Old 06-09-2006, 07:35 AM
  #7242
Thanks. The hobbyshop I work for stopped ordering from serpent years ago since nitro onroad kinda died in Memphis but has made a huge come back in the last year or two. Only cars that are run competatively are NTC3 and V1RRR. I'll probably run the Kyosho wheels and tires for now till Great Planes starts delivering GRP products and then try the serpent wheels.
NismoSkyline17 is offline
Old 06-09-2006, 01:18 PM
  #7243
Old 06-10-2006, 07:51 AM
  #7244
rmdhawaii's Avatar
Hi Guys,
How often are you replacing your 2nd shoe set?
Old 06-10-2006, 09:22 AM
  #7245
not until it stops working!
ae_ntc3 is offline
