Kyosho v-one rrr
#6946
Originally Posted by litespeed-dom
Ti with steel or aluminum overtime will bond. When I work at a bike shop in college, we use anti-seize grease on all Ti stuff. Put a very light coat of that grease on before you put the collar on will prevent the bonding.
Dom
Dom
#6948
Originally Posted by kidDynomite
Correct. It's called cold fusion. So if you're using Ti screws, don't bother putting one in threw the top deck to the steering post. Trust me, it's a pain. Even with the anti-seize, I think the constant vibes and cleaning cause it to fuse anyway. Broke the screw into the shaft, sucked. Dom, good thing bringing this up. I think it was a couple yrs since we talked about it.
cold fusion ? wasn't it a fleischmann and pons claim that was proved to be false ? anyways, i used a Ti main shaft before, it did deform on the tip area where it mate with the steel sleeve and i had a hard time taking it out. don't know if it is caused by "cold fusion" or by me tightening the screw too much. there is not too much material at the tip. i think it is ok to use it but don't expect it to last as long as the stock one. and it wears out quicker around the bearing area.
#6949
Originally Posted by MIKE ELLIS
What pulley do we have?????
The way I've got my car setup now, my rear tires wear pretty much flat. The rear left wears more than the rear right, so I swap them after every heat. At the moment, 10-12 tanks reduces the rear tire size from 65mm to roughly 61-62mm. Front wear is minimal and I didn't have a chance to measure them this morning. I already showed up late for work as it is.
Buying a tire truer is not a big deal (ka-ching for Hudy) and maybe our track doesn't require reducing the tire size (what do I know? ), but if the tire sizes truly make a performance difference, then I'm all for it.
Thanks!
#6950
Originally Posted by rmdhawaii
23T. I just saw the 24T in the parts bin when I was taking inventory. I'm still new enough at this to claim to be ignorant (well, maybe), so you guys will have to enlighten me quite a bit. I know that the tire truer is used to clean-up coned tires and I've seen that people where concerned about tire diameters, splits, etc., but no one really explained the technical reasons behind changing the size of foam tires. Lots of info on rubbers and the 24T.
Thanks!
Thanks!
For practising at a new track, I use 61mm fronts and 63mm rears while i am learning my way around the track....in 2 tanks your are down to 60 & 62 which is always a good place to start.
I dump the tires at 57 front & 58 rear as I start to tear up the chassis at that size. 3.5mm+ front and 4mm rear ride height.
I find the sweet spot at about 58-59mm front and 60-61mm rear
#6952
Originally Posted by Osiris 75
I'm definitely a beginner, but when I trued my tires for the first time, I did notice a considerable difference. I found an Integy Truer at tower Hobbies for $159 right now!!
Dom & Mike: You guys know anyone that owns the GQ tire truer?
http://www.competition-rc.com/GQtiretruer.php
There were a lot of interesting opinions in the now dead tire truer thread.
Jag: I know you got the Hudy.
#6953
Both Mike and I own the Hudy Fully Automatic.
I've not heard anything about the GQ truer since it just came out late last year. I had the opportunity to buy one before they came out, but I already owned my Hudy truer and absolutely love it! You can't beat a HUDY doing single pass cut to get tires down to 57.5mm!!!
Dom
#6954
Thanks. The Integy with the Hudy carbide cutter is certainly an option.
Rainer,
Take my advice.....I had Integy...Go HUDY
#6955
Originally Posted by robert maestrey
Rainer,
#6956
Thanks on the advice for the truer guys.
#6957
Originally Posted by dougday
Even if you do not cut your tires to 60 & 62 , you should cut your fronts to 2mm less than your rear.
So when you put your car on the setup board, what tire size are you using to set your initial ride height before making the camber adjustment?
#6958
I'll tell you one thing, we have guys still running Hudy truer from back in the days, back then it was batched at Serpent truer! We've had Hudy truer dropped from the hood of the truck onto the ground, still running strong.
This is the way I see it... Hudy is $400, last you 10+ years, 40 bucks a year, $3.33 per month....
Dom
Dom
#6959
Got it!
BTW, remember to measure your droop from the underside of the extension of the lower arms and not the uprights as is normally done with other cars. I have found that many people make this error in seting up there cars.
#6960
You guys are the best! I can't thank you enough for all of your advice and assistance.
