Kyosho v-one rrr
#511
Re: Re: Caster
Originally posted by ziggy12345
Add a small 3mm washer to the hinge pin during construction.
#512
Re: Re: Re: Caster
Originally posted by pelos
Sorry, but I do not understand your suggestion. What do you mean by hinge pin?
(different country, different language)
#513
No parts at fast and furonius as of yesterday
#514
Re: Re: At last.....New RRR complete!
Originally posted by Adoika
Kemy, it might be my eyes decieving me but your rear belt looks a little loose. Mine was loose until I realised that that the right rear belt tensioner goes on the left side and the left rear tensioner goes on the right side stupid me not reading the instructions correctly!
I looked at them theyre both where they should be but i had them set in the middle, should i change that ?
#515
Does anyone know where i could get the kyosho woven graphite front shock stay... thanks
#516
Re: Caster
Originally posted by NiMo
you might call it 'Suspension Shaft'
Now fits nicely.!
#517
I just placed in order last night for the Kyosho one at www.towerhobbies.com
#518
It's VZW052 V One RRR Carbon Front Shock Stay
#519
Yeah, they just changed the part name but the number is still the same.
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
#520
If you can get either one, I'd go with the Kawahara since it has 4 positions instead of the 3 on the Kysoho.
Jeff-does the Kyohso come with little blue spacers?
#521
#523
Not really, it's just that my Kawahara tower is broken and I don't have the stock tower. It's always good to have those extra holes just in case.
#524
I asked because the lowest hole on the Kyosho Fiber Tower is
equivalent (maybe even a bit higher) to the higher hole of the
stock one.
Are you racing this weekend?
#525
Doesn't look good for this weekend. My tank is leaking. Might rain too so...
