Kyosho v-one rrr
#5103
What servo horns would you recommend for the RRR, and where can I get them online?
#5105
Originally Posted by maskedrider
how long does we need to change the clute shoe ??? example by looking thur thru the UFO can tell?? The orginal/ brand new thickness is like how thick?
#5106
Does anyone have any pictures of how they ran all the wires for the servos and switch?
#5107
I used the 2 holes that are supoose to be for the transponder mount & with 2 zipties easy mounting for the steering servo as for the I wrapped on the bottom antenna holder until i decide were to puy or i might just leave it that way I don't use a switch
body is painted by phatskeemz he is on brooklynhobbies.com
#5108
#5109
710baby, that helps alot. I have KO servos, with a Li-Po battery and regulator with the switch.
#5110
Hey, Should i buy these hopups?
3Racing (#KV-023) Aluminum Pulley (19T) For V-One S/R/RR/RR Evo.
3Racing (#V3R-003) Front Oneway Pulley (27T) For V-One RRR
3Racing (#V3R-005) Solid Axis Adaptor For V-One RRR
3Racing (#V3R-006) Front Anti-Roll Bar Set For V-One RRR
3Racing (#V3R-013) Front Graphite Shock Stay For V-One RRR
3Racing (#V3R-014) Front Graphite Upper Bumper For V-One RRR
3Racing (#V3R-017) 64 Titanium Rear Main Shaft For V-One RRR
3Racing (#V3R-018) Brake Stopper Bulley (21T) For V-One RRR
3Racing (#V3R-019) Pulley Spacer Set For V-One RRR
3Racing (#V3R-002) Front Oneway Tube For V-One RRR
3Racing (#V3R-021) Brake Bracket For V-One RRR
3Racing (#V3R-023) Rear Graphite Shock Tower 3mm For V-One RRR
3Racing (#V3R-025A) Alum. Pulley (24T) For V-One RRR
3Racing (#V3R-027) Graphite Battery Base Holder For V-One RRR
3Racing (#V3R-028) Handle Bar For V-One RRR
3Racing (#V3R-029) Graphite Radio Tray For V One RRR
3Racing (#V3R-030) Side Stiffener For V-One RRR (R)
3Racing (#V3R-031) Light Weight Clutch Bell For V-One RRR
3Racing (#V3R-033) Throttle Servo Mount For V-One RRR
3Racing (#V3R-043) Graphite Receiver Plate For V-One RRR
Yeah Racing Bearing (#YB0128M) for Kyosho V-One RRR
and titanium screw set
How much lighter do you think my car would be? What other hopups should i buy?
#5111
#5112
#5113
I'll add to the good advice already provided in the last two posts: there's no need for that laundry list of parts. If you want to be different, that's a whole other story, but none of the parts listed are going to improve your performance. In many cases, drivers end up going slower, expecially with the lightweight chassis. The chassis to run is the thicker one-piece Kyosho chassis that doesn't have the battery tray mounted in the middle. This new chassis has the receiver pack mounted directly to the chassis. The chassis is more rigid and the extra weight is carried at the lowest point for the lowest possible CG.
#5115
Originally Posted by B4
Anyone tried this part yet VZ207. I have mine on the way from Japan.
