Kyosho v-one rrr
#4651
Originally Posted by Kyle Hazell
Hi Andy,
Pretty sure these are the springs from the V1S series. They come in a 3 pack, i think all of us used them when we were in Brendale last year for the Qld State Titles as it was quite bumpy.
I have tried the Phantom springs early on but pretty much found they were to stiff.
Regards
Kyle
Regards
Kyle
What springs have you found best for Fairy Meadow?....I havent raced there since the last Winternats, but heard that the track section in front of the drivers has "lifted" slightly and as a result "bounces" the cars a bit.
Cheers Andy
#4652
Originally Posted by dodo
i posted it sometime back, but i know the pain of going through the pages, so here you go
this is how i do it.
-after you assembled the shock piston, fill up the shock to the top. move the piston up and down until all the air bubbles start to come out. wait for the bubbles to disappear (might take few minutes depends on the wt). after it disappear, put a few more drops to the top again.
-put the membrane and press it down (not too hard) to let the oil flow out from the shock body (you might want to hold it it with cloth or tissue).
-put the shock cap on and tighten it.
that's how i do my shocks
and i hate to build associated shocks
#4653
Originally Posted by bosfan
i'm sorry tommi but I don't have a clue as to what that sheet is saying in relation to what springs will fit my rrr besides the black,silver,and gold.
#4654
For the guys doing the clutches. You should definatly get the hard spring and the setting on that is 2.1 it is a night an day difference. The guys doing the springs I have tried pretty much all the springs. The springs change the car very little there more for fine tuning. It depends on the track really also the fanthom/v1r springs are more progressive. The new evolva springs will need the smaller adjuster to use but are really stiff.
#4655
Originally Posted by AndyT ©
Thanks Kyle,
Cheers Andy
Cheers Andy
Probably std silver fronts and the "yellow" V1S (i think) on the rear with something like 350 wt oil all round. Start from there with 10,000 wt diff oil and 37's F/R, probably would use a Protoform Mazda 6.
Regards
Kyle
#4656
Trader Rating: 26 (100%+)
HEY, HAVE ANY OF YOU GUYS TRYED THAT RD LOGICS TURBO 3 PIPE NO YOUR RRR. I JUST GOT ONE TO DAY. I WOULD LIKE TO KNOW HOW WELL IT WORKS. THANKS
#4657
#4658
WERE CAN I GET THAT PIPE AND DO I HAVE TO GET A NEW HEADER WITH IT.
#4659
Get the mugen pipe with conical header and you will have a good pipe
#4660
Hi Andy,
Regards
Kyle
Regards
Kyle
Will try and hunt down some yellow rears, just in case Ric hasnt got any in stock.
Cheers Andy
#4662
Originally Posted by maskedrider
Hi guys, need yours advice ......
which brand is recommended for Pinion gear for RRR WCE?? My stock pinion seems to wear out very fast after few race... Like to get much stronger and durable which can last longer then the kyosho stock one....
#4663
i haven't got the chance to find out whether it's due to the hardened pinion or just improper meshing or the engine position shifted slightly hence improper meshing. whatever it is I won't be surprised if the hardened pinion caused it. after all the weaker one will wear out.
anyone else tried it?
#4664
Use the Kawahara pinions. They are a little heavier but lasts forever.
Dodo, the steel pinion is not the reason why you stripped your spur gear. It's probably the gear mesh.
I also heard Kysho is coming out with its own steel pinions.
#4665
Kawahara only makes first gear ones i can't find second. Some guy is selling them on ebay look like they are worth while. The hardened gear is not the reason because whatever kyosho makes there spurs out of it is strong. It was definatly your mesh or lack of up keep
