Kyosho v-one rrr
#4636
Ok Guys,
Question.....As your foam tires wear and reduce in dia. do you simply increase your ride height to compensate for this with the shock adjusters?
Would this not continue to throw off other settings????
Hope it's not a stupid question...
#4637
Not a bad question at all, actually.
When you adjust the ride height by adjusting the shock spring pre-tension adjusters, you will also affect the amount of droop the car has.
Just in case droop is an unfamilar term, here is what it is: take your car and place it on a flat surface. Under the weight of the car, the rear suspension "sags" down a bit. Now if you place a screwdriver underneath the chassis and slowly raise the chassis up, you will note that the suspension arms start to drop down as you bring the chassis up. At some point the suspension arm downward travel will be stopped by the droop or downstop screws. If you would have measured the amount of upward travel of the chassis from the point where the car was simply sitting on the flat surface to the point at which the wheels lost contact with that surface, then you would have measured the droop value.
Now as your tyres wear, the droop doesn't change - it is fixed by the settings of the droop screws, but the distance between the chassis and the ground does.
At some point you'll want to raise your chassis to maintain a reasonable ground clearence. This, as you know, is achieved by adding pre-tension to the shock springs. Now, in adding pre-tension to the springs, what acutally happens is the load from the springs forces the suspension arms down and therefore raises the chassis height. Now the arms are further "down" towards the chassis in comparison to how they were with the larger tyres. This also means that the suspension arms don't have as far to travel in the downward direction until the droop screws make contact with the chassis. So, to maintain your prefered amount of droop, you have to back out the droop screws a little.
If you measure the droop using hudy guages, then simply increase the droop (i.e. the arms need to droop down more) by the same amount as you increased the ride height by.
All of this will also affect the camber, so also check the camber values once your have got your ride-height and droop setup.
Just a quick note about camber: you can tell if your camber is appoximately ok, when your front tyres wear flat and the rear tyres cone in (i.e. outside larger than the insides).
Hope this helps.
Cheers, Mark.
Hope this helps.
Cheers, Mark.
#4638
what are you guys using for springs? are you just using the gold,black,and silver or are there more springs i can use to fine tune this car?
#4640
#4641
Originally Posted by AndyT ©
According to the 200mm Worlds video, theres also some green springs available but I`m yet to see them.
#4642
This should be handy to keep...
#4643
And this could be helpful, I used this to get the spring rates for my RRR.
http://www.stockcarproducts.com/pstech10.htm
#4644
Springs
Pretty sure these are the springs from the V1S series. They come in a 3 pack, i think all of us used them when we were in Brendale last year for the Qld State Titles as it was quite bumpy.
I have tried the Phantom springs early on but pretty much found they were to stiff.
Regards
Kyle
#4645
Can anyone give some good advice on how to assemble/fill up the shocks with oil? This is my first time with bladder shocks, and I'm not sure if I got them assembled the right way. Previously with my NTC3, I was able to get the suspension arms to fall down freely when lifting the car up (with the shocks and tires on); but can't seem to do so on my WCE RRR. Any advice will be very much appreciated!
#4646
this is how i do it.
-after you assembled the shock piston, fill up the shock to the top. move the piston up and down until all the air bubbles start to come out. wait for the bubbles to disappear (might take few minutes depends on the wt). after it disappear, put a few more drops to the top again.
-put the membrane and press it down (not too hard) to let the oil flow out from the shock body (you might want to hold it it with cloth or tissue).
-put the shock cap on and tighten it.
that's how i do my shocks
and i hate to build associated shocks
#4648
Originally Posted by mrgsr
so you fill the shock to the top and then let the excess go by pushing down the membrane ?
#4649
Originally Posted by dodo
i posted it sometime back, but i know the pain of going through the pages, so here you go
http://www.rc-toro.com/product_info....roducts_id/329
#4650
i'm sorry tommi but I don't have a clue as to what that sheet is saying in relation to what springs will fit my rrr besides the black,silver,and gold.
