Kyosho v-one rrr
#257
wouldnt it be
first/second
pinion: 16/21
spur: 61/56
I have changed to the 22/56 second 5.09 second gear but first gear is stock. My tracks backstraight is about 50 meters.
first/second
pinion: 16/21
spur: 61/56
#258
#259
#260
The 22/56 2nd gear combo works out great for a 50m backstraight with 57mm tires. Well 59mm rear and 57mm front.
#261
#262
Yes initial d I am running smaller tires hence the need for taller second gear. It is all about how the car performs and I found a sweet spot (on my car) with this gearing and 59mm tires.
racing4evo: It is good to see that we came out with the same ratios on a similar sized track. I am also running 59 rears
also what are your impressions of this car? I love mine and am so glad I own 3r!
#264
Originally posted by wad
How about 1st gear
Is there any way to don't run split, or you have to
My local track also has 50m straight
How about 1st gear
You can set the car up without overdrive by using the optional 24T pully in front which in included in the kit.
I geared my 1st up slightly by using the 60T spur instead.
#265
Originally posted by jeffreylin
So Walter, does this mean you are getting the RRR?
About my new car, my priority is wait for the G4
But it is taking toooo looong
I'm saving money, so if the G4 doesn't show before I get money for the 3R, I will get the 3R
#266
The car came geared with 59/16 and 56/22. I thought the car could use a little bit more torque so I just put the stock 61 spur back on and I'll see how that works out next time.
#267
Originally posted by ziggy12345
Ran the FW-05 around tibby today and broke the front shock tower. I was on the site ordering the shock tower and my finger slipped...... The RRR is on its way!! LOL..
#268
#269
My friend Dino has one and it's very very light. See pictures in this thread.
#270
Originally posted by Sow&Steady
Careful with ordering from outside the EC ... might get taxed. Then again ... NiMo, your got in a bunch of FW05s without tax right? How did you do it?
