Kyosho v-one rrr
#2266
Originally posted by NiMo
64 hours after I ordered it, it was delivered, in fact less than that as it was here when I got home from work an hour ago
I hope Kyosho read my review *cough* and improved the screws.
#2267
Originally posted by markp27
Take your time with those front arms, NiMo - they're a bit tight out of the kit. It took me a couple of hours to get them to drop just nicely, but I think the work was worthwhile.
#2268
I've been running and building Kyosho kits since 1997 so I'm a wee bit wiser on how to treat the screws (a little bit of grease in the hole first works wonders)
#2269
hello.
just get a new starter box for my v1rrr... its a true start universal starter box. any comments for that...?
#2270
hi
other view.
#2271
Re: hi
Originally posted by NovaKing
other view.
other view.
It has been OK so far...
Only problem, you have to place the stoppers behind the front wishbones...
So you have to sit the car on the box from the front towards the back side...
#2272
Use a gel cell instead of 2 stick packs and buy the Power Panel to hook up a glow igniter. It lasts a log while with the gel cell and you don't have to worry about an uncharged glow igniter.
#2273
fort myers gearing
does anyone have a good recomendation for what gears to use at fort myers... thanks in advance.
#2275
Originally posted by wad
Hey Jeffrey, can you help me out with part # for the longer side belt, to run 24 side/front pulley?
If you help me, I promise you that I don't goint to overlap you next sunday
It's VZ237 side belt 387.
Just help me tune my engine.
#2276
Re: Re: hi
Originally posted by SpeedsterRRR
I have the same starter box!!!
What i did was got the car aligned properly so the flywheel was over the starter wheel, then I marked the position of pinion gears onto the starter box and engraved this into top of the starter using a dremel........
Now to start the car its simply a case of putting the pinion gear over the marking and bumping the car to start it
As mentioned previously.....go with a 12v 7ah gel cell in this starter box......it gives a lot more life than twin stick packs.
Cheers
#2277
Originally posted by jeffreylin
So if I give you the wrong part number maybe I will lap you instead?
I think you motor is good already, sorry but if I tune your motor, I will make sure that it is slower than mine
Thanks!!
#2278
What motor is that?
You guys should try the new 2deg. front hubs!
#2279
Originally posted by Racing4Evo
What motor is that?
What motor is that?
