What would cause wheels be able to shake >
Old 04-26-2011, 03:52 PM
Trader Rating: 26 (100%+)
Default What would cause wheels be able to shake
What would cause there to be play in my wheels when mounted to the car? I can rock them side-to-side. Is this normal?
SDelaney is offline
Old 04-26-2011, 03:57 PM
jammin32j's Avatar
Most of the time it is just bearing slop. A little is normal.
jammin32j is offline
stallen50's Avatar
Trader Rating: 30 (100%+)
your steering ends,tie-rod ends and or plastic is worn down. Some is ok but you dont want it to sloppy
stallen50 is offline
Old 04-26-2011, 03:58 PM
stallen50's Avatar
+1 on the bearing slopp. Sorry missed read the the post
Old 04-26-2011, 04:07 PM
jammin32j's Avatar
Your answer makes sense too, could be either or depending on what type of wheel wobble he is talking about.
Old 04-26-2011, 04:17 PM
If you make Bartow maybe I can finally meet you and ask you some basics
SDelaney is offline
Old 04-26-2011, 05:25 PM
jammin32j's Avatar
I will be at the Asylum Friday and Saturday and Bartow on Sunday, I will be more than happy to help. See ya there
Old 04-26-2011, 06:43 PM
losi_racer's Avatar
Trader Rating: 25 (100%+)
you have a losi your fine dont worry about it
losi_racer is offline
Old 04-26-2011, 08:23 PM
Integra's Avatar
I concur.
Integra is offline
Old 04-28-2011, 09:24 PM
Yosh70's Avatar
Trader Rating: 17 (100%+)
I have a Losi 8T 1.0 Tekno converted and just took it out for a run on the street after finally getting everything together.
When in reverse, the front tires wobble back and forth. Not a big deal but is there something to check/tighten or replace? Had a used DS1013 servo that I threw in which seems ok, not the strongest (180oz/inch) but it seems to do the job.
Yosh70 is offline
Old 04-29-2011, 06:33 AM
token's Avatar
Why are you using reverse? I have never seen a Losi go backwards.
token is offline
Old 04-29-2011, 07:54 AM
R/C Tech Elite Member
Spads11's Avatar
Trader Rating: 33 (100%+)
While checking all of the other things posted, you might want to look at your tire balance as well. Truggy tires do need to be balanced more depending on the brand, how you store them, how old they are (# of runs), etc.
Spads11 is offline
Old 05-02-2011, 06:31 AM
Integra's Avatar
It might be the Shake of death, How old is the 1013 ? Brass gear's and weak top cases have a tendency to have the shakes after a while.
Integra is offline
Old 05-02-2011, 06:43 AM
token's Avatar
The question should be does it do the same thing going FORWARD?
Am I reading this wrong? "When in reverse"?
token is offline
Old 05-02-2011, 07:24 PM
Yosh70's Avatar
If it the tires shook back and forth going forward, I probably would've said that.
Going in reverse is when it happens, you know, backwards? Thats the opposite of forward.
Yosh70 is offline
