Old TC Cars - Still Racing Competitively
#634
I guess that the case I could point to is that nobody on here is racing a Losi Street Weapon, and for good reason, that car was really a 4wd buggy just pretending to be a touring car, and has no continuing support.
#635
With enough work and aftermarket parts, maybe, and while you you can probably take any old heap and make it work, some can't really be made to be fast. The car needs to have good bones, meaning that the chassis has to be balanced, its race weight needs to be close to the legal number, the suspension geometry needs to be similar to what works for rubber tire racing, the driveline needs to be efficient and durable, and the cars still need at least a small parts or aftermarket following so you can replace broken parts. If the car itself is lacking in any of these areas, the car needs have the aftermarket upgrades necessary and to go fast.
Gil Losi Jr. thunk outside the galaxy with those designs, but a lack of understanding low mass racing cars and their design/suspension tuning backfired. Again, that's why we are revisiting these old cars, fixing them and pitting them against cars that can only claim to be optimized (they aren't, nor will be in the next 2-3 years). Hey, if you want some pointers, for a nominal service charge you can reach Nirvana tonight
#636
The tc3 was taken out by Hara in the third final on the first turn. Hara should have been penalized for it , if not disqualified. There were plenty of other races where the tc3 was cheated out of a win... I guess the teams should have been more vocal back then....Nowadays, you won't get away with it...
#639
Your Tamiya-branded undies are showing, just thought someone should tell you.
#640
Sorry, but you're absolutely wrong. They can be just as competitive as a 414. The only things that prevent them from being quite competitive overall are a lack of gear diffs and DCJs. You can easily modify the motor mounts to allow for the tall gearing of today's motors.
#641
https://youtu.be/4afSNqAGvzk
#642
Barry was not the one Hara took out in 2000..... It was someone else in the first turn of A1 final...Mark Pavidis.....
#644
Correct... So I had Dynotech Racing make me a few replicates in 7075 aluminum: it shaved six grams per pair...I also had some rear tc4 axles made in 7075 aluminum to work with the plastic bones(another 6grams shaved per pair). I will be testing them in my 17.5t car....Wish me luck....
#645
While the 414 is great, the TL01 is greater
At least it is tough to beat in a clean wiring contest
+ YouTube Video | |
