Need some part suggestions >
Old 04-12-2011, 11:16 AM
Mind_Reader7's Avatar
Default Need some part suggestions
I'm running a Traxxas Jato.
First up, I'm after a recommended clutch bell and spur gear. Just tooth sizes, because I can find them on my own, mostly after speed.
And second, these Anaconda tires suck. Could someone please recommend a set of 4, preglued tires? Or even just 2 different sets for back and front if it's better. I do a bit of road, but mostly want for loose dirt. No so much after fashion or anything, price isn't a serious problem, but I don't want to go buy aluminum rims with expensive tires.
Last thing, I don't think it exists, but a metal transmission case? Several screws mount the transmission to the chassis, and 2 of the screws mount to the engine. After taking these screws out a few times, it threads the plastic, and you need a new case (serious PITA).
Thanks in advance.
Mind_Reader7 is offline
Old 04-12-2011, 11:17 AM
Omfg, I just found a billet gear box (I spent 30 mins on the Google machine at one point). After 2 minutes on the Integy site, I found it.
Old 04-12-2011, 11:20 AM
token's Avatar
Thanks in advance.
BAM. All the Alum parts you need. And tires.
http://www.integy.com/st_prod.html?p...591&p_catid=91
token is offline
Old 04-12-2011, 11:23 AM
I just found that hey, almost came in my pants.
Still after some reccomendations as to gear size + wheels.
Old 04-13-2011, 07:25 AM
Wheels are sorted, got some 17mm hex adapters, I can use 1/8 wheels now.
Still after what gears I should use.
Old 04-14-2011, 09:00 AM
Decided on 20/38. Will let you know how it goes.
