Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)
#1082
Hey Christian do you think its possible to make Thompson CVD's small enough for a TC? Would it be cost prohibitive?
http://www.youtube.com/watch?v=UEvaOg7glKk
#1083
#1084
#1089
When can we expect the Chassis in Europe?
#1091
I will send you a PM.
#1093
Bummer.
I did notice that you run a full top deck. Since you are on asphalt, at least flip it over and use button head screws instead of the countersinks. Leave the forward most rear screws off the car.
For extra flex look at the top deck of my car in the pictures. I cut the rear cross member and the front as well. This should aid on your lower grip days.
I run my car this way on our high grip treated asphalt track too.
Also, post your set-up so that I can check it out and offer some suggestions.
#1094
I ran the standard setup you posted a couple pages back. Used Solaris medium tires. Ended up removing the rear swaybars which helped some fish tailing I would have in some spots on the track. Will definately adjust the top deck next week. I was hesitant to make any radical changes because the track seemed way different from the normal race traction.
One question I had on the setup is where it lists RSD + 3 on the camber link positions. I assume the 3 means a 3mm shim?
By the way there were no durability issues which I wouldn't think there would be but you never know.
#1095
Typically, I have found I get more exit traction with a sway bar on vs off.
Another thing to do is run lighter rear diff oil.
Are you running a front diff? I would go with the spool. It should generate more traction. I have never found gear diffs to be better than a spool, and I have noticed that most pro drivers only use them in extreme high grip carpet races. I know some people will run them on big sweeping tracks, but my experience on larger tracks is a bit limited.
With Solaris Hard, you are going to be a little limited on traction if the track is dirty, but they are pretty good even when cold outside. We use black can Paragon on them and they hook up pretty well if the track is cleaned and treated. Mediums I have found are only good for a couple of runs before they drop off a lot. It's more of a carpet tire than asphalt. Try hards and they might surprise you in that they are better.
