Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)
#827
Looking really good Cristian.
Can't wait for any more progress on the chassis.
#828
Sick Cristian just sick. If I would of had one of these chassis I may not havr thrown my Tc6 in the trash before my main at the Nats.......
I dug it out of the trash and I look forward to getting a RSD6.1 chassis.
Keep us posted.
Keep us posted.
#829
Always coming out with cool stuff Cristian.
#831
Are you using a self cut AE top plate? Because the standard one touches the motor and the flex is restricted to one side. I filed mine down 1mm and now it's much better the car flexes left and right more equally.
#833
That is fantastic! Congratulations!
I will look forward to the release date!
#834
I never thought of that, but now that I look at it I wonder why Associated didn't think of it either.
#836
trying to ask, when will RSD AE TC6 2.5mm Carbon Rear Bumper be available? thanks.
#838
The problem with mounting the fan in front of the motor is that it gets in the way of all the wiring. We are still keeping one hole at the back of the motor which you can use to attach the fan mount to the chassis. You will also be able to use our fan mount base to servo tape it in place.
#839
Hi Christian, can you Tell us why you changed the Way of fixing the batterie with Tape in comparison to the original TC6 chassis? For me it was a better Solution than the TC5 had, because you save tape it is easier to install and it is not touching the ground and therefore not getting damaged outdoors.
#840
Indeed. I also like that feature on the TC6. I don't like the tape going under my chassis. Is that something you could think about?
