Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc) >
Like Tree4Likes
Old 03-20-2013, 08:03 PM
  #2056
CristianTabush's Avatar
Trader Rating: 13 (100%+)
The evo kit should be back in stock around Friday. The tuning kit will be re released in a different variation sometime next month.
CristianTabush is offline
Old 03-20-2013, 08:33 PM
  #2057
Autocratic's Avatar
Trader Rating: 26 (100%+)
Good to know. I think the 6.1 is going to be my next car, so looking for traction options on low-med grip carpet.
Autocratic is offline
Old 03-21-2013, 10:36 AM
  #2058
Re-stock and new items arrived today.
Back in stock are the EVO Chassis sets, XRAY, TC6 and RSD6 battery hold downs.
Also in the next couple of days we will add to the site the new arrivals:
-Machined Delrin Pistons for T4 (3/6 hole and 4 hole)
-T4 Carpet Springs
-T4 Asphalt Springs
-T4 Bumper Brace
-T4 Full Lock Steering Stand Off
-TC6 Short Shock Tower Conversion Kit
Old 03-21-2013, 04:02 PM
  #2059
hanzo3's Avatar
Trader Rating: 55 (100%+)
My narrow dcjs are binding. Anyone have this problem? I followed the directions on the site. Both sides should rotate freely right?
hanzo3 is offline
Old 03-21-2013, 05:40 PM
  #2060
They should not bind. There might be a part that is slightly out of spec or dmaged. Please send them back and we will issue a replacement.
Old 03-21-2013, 05:47 PM
  #2061
The Captain's Avatar
Just posting positive feedback for RSD. They forgot some parts on an order and took care of it no problem. Great company and they will get my business again!
The Captain is offline
  #2062
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
CT - any news on bumpers?
hanulec is offline
Old 03-21-2013, 06:05 PM
  #2063
Budman's Avatar
Trader Rating: 22 (100%+)
Originally Posted by zixxer
part number or link to the reflex part ? i looked through the site but couldnt find it ...im currently needing the best idea for horn/saver on the rsd 6.2
http://www.stormerhobbies.com/cgi-bi...c=ns&pn=KIM200
Budman is offline
Old 03-23-2013, 09:58 PM
  #2064
Default Tons of Items in Stock!!!
RSD076 Lowered Shock Tower Conversion Kit
RSD077 RSD XRAY T4 Asphalt Progressive Spring Set
RSD Carpet Linear Springs
RSD XRAY T4 Aluminum Bumper Brace
RSD XRAY T4 Machined Delrin Pistons 3/6 Holes (1.0-1.2mm holes)
RSD XRAY T4 Machined Delrin Pistons 4 Holes (1.0-1.2mm holes)
RSD TC6.1 High Speed Bearing Kit
RSD XRAY T4 High Speed Bearing Kit
RSD XRAY T4 Increased Steering Throw Steering Rack Stand Off
Old 03-24-2013, 08:45 PM
  #2065
Francis M.'s Avatar
Like the new products, when are the spool cups going to be available again?
Francis M. is offline
Old 03-24-2013, 09:52 PM
  #2066
Spool cups should be available inside of 2 weeks I hope.
Old 03-24-2013, 10:01 PM
  #2067
Francis M.'s Avatar
Thanks for the quick reply, will also order the shock tower and new spring set when the spool cups come in....
Old 03-24-2013, 11:19 PM
  #2068
corallyman's Avatar
Trader Rating: 101 (100%+)
Cristian,
I was reading your post in the Xray thread about your new springs. How many sets of each springs do you test before you list them on your spring chart, is it always 5 sets and then do you use an average for the result? Also do you use 5 sets of the other manufacturers springs as well? Hpi, Yokomo, etc. Just when I think I have it all figured out, the springs that I think I need are different
Thanks,
Steve
corallyman is offline
Old 03-24-2013, 11:28 PM
  #2069
Well, ours we do as many as 10 sets, but in an effort to remain consistent we do an average of a total of 10 springs (5 pair).
We test the springs at 0.075, 0.125 and 0.250 inches of compression. This is most of the "usable" range of springs. We observe the behavior and average the value of these 3 numbers.
In the case of our new progressive springs, the number variation we were getting was so large, we decided to call them as they are "progressive", progressive springs.
Rates are something that should be used as a tool, but is never the end-all be-all. The feel is the most important thing about the spring. Lap times can be similar, but how comfortable a spring makes you when driving your car is very important. Many times 2 springs might give a similar or equal rating on our machine, but the feel of the spring on the track is very different.
Case and point is our Asphalt Green and Asphalt Silver. These 2 springs are nearly identical in rate. However, the Green is a spring with less coils and 1.4mm wire, the Silver has more coils and 1.5mm wire. The feel on the track, is completely different, but each spring has a nice quality about it in the neat to ideal spring rate range for the T4 on asphalt.
Old 03-25-2013, 05:12 PM
  #2070
What would be a good starting set up for asphalt with the new short shock conversion on the tc6?
jake alton is offline
