Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)
#1621
#1623
Your thesis seems to intend that you loose a little grip in the rear. Or do you mean it swings better, because the resistence effect of the bending joint is not there?
#1624
Kevin, as there is less friction in the joint, the car should generate less rear grip which will cause the floating feeling they describe. Driveshaft angles create a "bind" that has been observed to cause higher grip levels do to the straightening forces of the shafts being applied.
Using a dcj in the rear should be good under high grip conditions, where you want to free up the car a bit.
#1625
Ok well now you have given me the perfect excuse to buy more stuff
#1626
Please don't get me wrong, but can you really recognize it, or is it more of a feeling? I am asking it this way, because the degree of the joint is so small in comparison to the steering in front.
#1627
Team EAM
EA
#1628
What are the major changes to the V2 DCJ's
#1629
Thanks for the detailed explanation guys!
#1631
Okay don't divulge, just hint a little.
#1633
