sc10 setup
A few things I did to really help with handling of the SC10. I ran 30 degree castor blocks, T4 trailing spindles, blue front springs, losi black 57 pistons with 32.5 shock oil. In the rear racer edge 1 degree toe-in aluminum hubs. Blue springs losi red 56 pistons with 30 weight shock oil. I raised in the inner ballstuds to 3 0.0030 aluminum washers for the roll center adjustment. In the front 2 0.0030 washers for the front roll center. I layed the front shocks all the way in front and rear.
For the gear diff I ran 2 of the 4 spider gears ran 2 shims on either side of the cross pins and coated the to large gears with 100k OFNA diff oil. Hope this helps you out a bit.
