Barracuda from Alex racing
#541
Re: Ball diff or One-way????
Originally posted by martinm
What is the best for a little and with a lot of hard corners,and not so much grip??? Which is the best set-up?? I tried with one-way and was really difficult to brake (I know one-way, in front ). It's possible to use a front ball diff?? Wich is their part number??
Thank's a lot
Thank's a lot
#542
Re: Re: Ball diff or One-way????
Originally posted by fai
Martinm: Oh... I find myself can brake "softly" if running with front one-way only... I think you can reduce the brake of your ESC. I think there is a package of ball differentials... I'll check for you then!
Wich setup can I use to start?? I have tryed with take off 22 and the book setup. Any idea??
#544
what do you mean JDM_DOHC_SiR???
Sorry
Sorry
#545
JDM_DOHC_SiR
Do you have a Honda Civic?? (DOHC SIR???) I have one too.
#547
Re: Re: Re: Ball diff or One-way????
Spring: 1.4x5.50 front/rear
Oil: yokomo #450 f/r
(Adjust oil/air mixture so the dampers rebound very slowly.)
Damper length: 59.5/63.5mm f/r
Rebound: 2.0/5.0mm (adjusted by down-stop screws)
(Assume tire radius=31.0mm)
Roll bar: 1.2/1.2mm f/r
Ride height: 4.5/5.0mm f/r
Toe: -1.0/2.5 degree f/r
Camber: -0.5/-0.5 degree f/r
Upper arms on uppermost holes of front/rear hubs
Upper arms height: approx. 2.0/5.0mm above upper chasis
Damper holes: 3rd outermost f/r
Lever: 60/75%
Front skid: 0.5mm below front A-arms
Rear anti-squat: 0
9-Turn motor
72 spur gear
22 pinion gear
no centre one-way
hard A-arms
Please correct me if I miss out anything!
#548
Thax I will try this setup!!!
#549
hi, can anyone help me. i'd like to know hobby shops located in kyoto preferably near kyoto university. pls include exact address, tel no or if possible email add and website. thanks!!!
#550
to counter torque steer where do i need to put weight??
#551
#552
LOOKING
i need 2 sets of steering knuckles .....i complete ball diff ,a few sets of red alum axles ..and 2 of the alum transponder mounts i see on most of the alex cars
#553
I think we can place weight on the motor side as those electronics should be lighter than the battery! But I'm not sure will this makes torque steer even worser...
#554
fai - any idea how much so i put when using 2400/3000 batts??i dont have any tweak station nor a scale...so if u could give me an estimation of weight i could trial and error from there
I think you can reduce my weight suggestions a little bit as you're running 2400/3000 batts.!
#555
2400/3000 batterys
I use an Excel chassis on my normal cuda and for the weight dist` with the 3000 Panasonics I usually put 10g right in front of the motor and thats it but before with the normal chassis I used a set up very simillar to Fai`s but without the weight in front of the servo
-Dave
-Dave
