Barracuda from Alex racing >
Like Tree1Likes
Old 08-25-2003, 08:59 PM
  #3961
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by Herminator
So why was there tweak in the first place?
what have you done to the steering to introduce the problem, since surely the only way to change the height they need to be is by changing the bulkhead heights or not using the diff covers but there are shorter posts for that already.
Or has a different chassis/topdeck combo vaused some alignment problems?
Thats made me think, with the PAL R2 conversion having machined section for the bulkheads and motor mount, won't it also need slightly shorter steering posts. Is this going to be a dremel job? or will hey machine the chassis at the steering post holes or include shorter parts needed?
THhere were some issues with the upper deck were the Steering posts mount ....the under side of the upper deck
-Dave
JDM_DOHC_SiR is offline
Old 08-25-2003, 09:00 PM
  #3962
Regional Moderator
ImGoinRCn's Avatar
Originally posted by Randman
I'm the guy with the pink cuda...
let's pretend that dave has a pink cuda so we can say he is the one in the pink shirt
ImGoinRCn is offline
Old 08-25-2003, 09:02 PM
  #3963
Herminator's Avatar
-Dave
thanks for clearing that up.... I think
Herminator is offline
Old 08-25-2003, 09:04 PM
  #3964
Herminator's Avatar
Randman is the Pink man, Dave is the guy with the big biceps after carrying all his cuda's and cells
Old 08-25-2003, 09:14 PM
  #3965
Herminator's Avatar
On a side note about my local club racing, we've just ordered the Road Rail system, so no more rolling and unrolling of long fire hoses that then need to be taped or nailed down
Should look a lot more profesional too, and stop some of the all too easy corner cutting you get when you use flat fire hoses
Just hoping I get my next order from Steve by next Monday, it's looking like it will arrive on Monday at the earliest I need the extra diff I ordered or it will be one way slideyness on the wooden floor it can be done but it takes big *ahem* to get your thumb to keep on the power in every corner even though everything tells you it has to go slower to make it, you still need to slow down but long before you arrive at the corner very odd and very difficult not to spin out atleast once a lap
Old 08-25-2003, 10:07 PM
  #3966
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Originally posted by Gazza_D
If it goes as well as it looks....look out world!!
When is its first outing???
Its got the seal of approval from my missus so.......
better not, got enough with Web and new 1/12th required to go another Cuda. LOL
It's getting raced tomorrow night in the brushless class at SoCal
Randy Caster is offline
Old 08-25-2003, 10:12 PM
  #3967
Yea thats why I put the extra washers in there just to make sure that you had enough to fix that little problem
Your taking that car to the track tommorow right..?
Dave should be there..so please give him the "GOODS"
-Dave
Those pink washers are cool
I have Dave's "STASH" in my pit bag already
Old 08-25-2003, 10:14 PM
  #3968
Look closely at the PAL conversion pics, the part of the chassis where the steering posts mount is machined down, use the stock posts with no mod.
Old 08-26-2003, 12:31 AM
  #3969
Thanks for giving it to him
-Dave
Old 08-26-2003, 01:52 AM
  #3970
Regional Moderator
-Dave
the upper deck had counter sunk holes there where the post mounts . it was done that way so you could use it with out shorten the steering post. the movement is free and if you installed the short post then you simply added a washer no biggie. but i never had a problem with it.
Ko Racer is offline
Old 08-26-2003, 02:35 AM
  #3971
ahhh thats why it had a few problems then when I changed it over to the short posts
-Dave
Old 08-26-2003, 09:22 AM
  #3972
Well our work was done for nothing though. I still got it 100% tweak free which was time consuming, but should be very worth it on the track.
It gets it's debut in BL today
Old 08-26-2003, 09:26 AM
  #3973
rc-zombies's Avatar
How'd you get rid of the tweak?... my WEB has a bad tweak.
one day its' on the right front and the next day it's in the rear..
can't figure it out.....
I laid the chassis down on a flat glass panel...unscrewed the upperdeck & bulkheads and retightened.
rc-zombies is offline
Old 08-26-2003, 09:31 AM
  #3974
If you can't get rid of it, just have a friend at the track hold down on the front and rear shock towers (pretty hard) and tighten all of the bolts down in a star pattern, you can usually get a perfectly flat car by doing that.
Old 08-26-2003, 09:39 AM
  #3975
rocketron's Avatar
Trader Rating: 16 (100%+)
I've found the shock mounts can shift both front and rear. if you loosen them hold them down and tighten all will be good. i have recently countersunk the two top srcew holes and for the last couple weeks have not had this problem any longer
you may want to try this
rocketron is offline
