Barracuda from Alex racing
#3031
Originally posted by Herminator
Don't see how you can get much end play in the stock shaft, mine fits tightly in the bevel gears, so all play is in the gears/shaft holders and there isn't much there. hmm.....
#3032
Originally posted by RedBullFiXX
Remove the shaft assy, loosen the set screws in the blades, gently tap the ends down on your workbench, this should give you a mil, or two shorter assy, the carbon shaft does fit nice and snug in the aluminum blades.
#3033
R/C Tech Elite Member
#3036
Dave: You got PM about knuckles.
#3037
12-cell holes chassis??
Dave: Do any Japan companies think of producing a lower chassis with 12-cell holes,similar to XRay EVO2?
So Cuda users can choose to put the battery on either side.
Is it good??
Is it good??
#3039
Re: 12-cell holes chassis??
Is it good??
Is it good??
#3043
Re: Re: 12-cell holes chassis??
Then the motor wouldn't have it big hole and so would have to sit higher, which means a different motor mount, and there would have to be different holes in the chassis for the motor mount screws too, looks like a kinda big job.
#3045
Regional Moderator
Originally posted by xxxkat
KO Racer,Thank you,That was so cool.Now I can at least take the R2 apart.
