Hobbywing ESC Settings ONLY >
Old 10-22-2014, 04:48 PM
  #286
R/C Tech Elite Member
JayL's Avatar
Josh: a v3.1? the only times I have seen this it was going bad. For some reason sometimes they die slowly and start working less and less once one of the FETS goes
JayL is offline
Old 10-22-2014, 06:55 PM
  #287
Josh-n-ya's Avatar
Trader Rating: 95 (100%+)
Yeah thanks, I was talking to a few other people as well about it. Looks like its gotta go see the doctor.
Josh-n-ya is offline
Old 12-19-2014, 12:35 PM
  #288
waltss2k's Avatar
Just wandering, can you run a J Stock with a 1s and 13.5 motor for WGT.
waltss2k is offline
Old 12-20-2014, 12:15 PM
  #289
Trader Rating: 16 (100%+)
Josh,
Time for you to get a Hobbywing 1S ESC...
Bill
Still Bill is offline
Old 12-05-2016, 01:48 AM
  #290
anyone have any tips or advice on if its possible to improve the brakes on a HW 2.1 ESC
has the newer software with turbo and boost
running it with a HW 7.5 motor in a B6 buggy
TX is 100%, ESC is 100% but indoors on carpet full brake just about hauls it up at end of straight in maybe 5 yards, its really poor, I cant go in hot brake late like the others and get nice tight turn.
is this just a trait of HW esc, poor brakes??
sorry, admin pls delete, found this thread via google, but didnt realise it was onroad and very old, until I posted it
TonyCooperUK is offline
Old 12-05-2016, 02:20 AM
  #291
Andy63's Avatar
If i'm not remebering wrong, i think you need to turn up the initial brake setting. I think that is one solution on the 2.1 ESC.
Andy63 is offline
Old 12-05-2016, 10:11 AM
  #292
RoyB's Avatar
Trader Rating: 19 (100%+)
Set the reverse to 100%,
RoyB is offline
Old 12-22-2016, 03:17 PM
  #293
Default V10 G2 5.5t v3 settings
I've moved on up from a Hobbywing V10 G2 13.5t to modified using a Hobbywing V10 G2 5.5t motor on HW V3 120A. I've used the Profile 1 (modify) to set ESC but overall it doesn't seem as fast as it should compared to the boosted/turboed 13.5t.
Are there any suggestions regarding if you can add boost etc to a 5.5t motor - some of the HW set up sheets have lots of boost which according to HW is not applicalbe to a 5.5t motor?
My current FDR is 6.9.
Also, is there any quick way to determine if the sensor cable is okay? I can't detect any change with or without the sensor cable plugged into the motor (start with it in, rev, etc - turn off power, remove sensor cable, rev etc = seems the same)
hotshotnz is offline
Old 12-29-2016, 10:11 AM
  #294
RC MARKET's Avatar
Trader Rating: 12 (100%+)
XR10 Pro Optional Case
Attached Thumbnails Hobbywing ESC Settings ONLY-hw-30850006.jpg   Hobbywing ESC Settings ONLY-hw-30850007.jpg
RC MARKET is offline
Old 12-29-2016, 05:31 PM
  #295
My wife got me a Hobbywing Justock Club Spec and the LCD programming box. Is this particular Hobbywing decent? I'll be racing 21.5 blinky at my local track. Any specific setup tips I should know about other than what I"ve read here? Thanks!
FloridaST is offline
Old 12-29-2016, 05:38 PM
  #296
tbrymer's Avatar
Should be great. Just check to make sure you have the drag break setting to what you want. I think the default might have some drag break in it, and if you don't want any, you will have to change that setting.
tbrymer is offline
Old 12-29-2016, 06:23 PM
  #297
Thanks I'll check that. It's my first brushless setup so I'm learning as I go.
Old 01-12-2017, 09:19 AM
  #298
nashrcracer's Avatar
OK brand new XR10 PRO 1S can't get it to set. the green light blinks when I turn it on and it's not reading neutral I would assume? turn on holding the button I get nothing. onlty way to turn off is unplug button unresponsive. any ideas? or is there a better thread to ask this?
nashrcracer is offline
Old 01-12-2017, 09:42 AM
  #299
Trader Rating: 27 (100%+)
Try reversing the throttle. Mine did the same thing when I got it in the mail. I even had to use my wifi express to flash it again before it started working. Haven't had a problem since. This was on the xr10 pro.
Jwilliams5 is offline
Old 01-13-2017, 10:45 AM
  #300
hmm didn't fix it. back to the drawing board..
