Hobbywing ESC Settings ONLY
#226
Ok I have a problem, the xtreme stock speedo my mate has won't flash. When you click upgrade it just comes up with an error message saying it can't install the firmware.
I installed the LCD box software (Hobbywing_USB_Link_setup_V1.64_111011.exe), updated the box to the latest version firmware (which was 1.0.1.8 or something) then tried to choose 930 stock from the list but no go. Tried all of the V3 firmwares available and still no go.
When my mate first received the speedo it was flashed to 508 for running at the club, it was then re-flashed to a stock software (don't know which one) and it was re-flashed when he was out racing last week by a local guy to 323 stock as he was having some problems with his new motor (x12) and now it won't reflash. Any ideas?
#227
#228
It doesnt work, it won't flash to any firmware in the 1.64 release, I would reflash it with 323 and try from their but 323 isn't in the list for me to try.
#230
V3 with v3.1 firmware
Hi guys i have just update my V3 to the latest firmware (3.1). I have very little brakes, any one with the same problem ? i am using a thunderpower 13.5T motor, fdr approx 6.0 on tarmac with a 40m straight
#231
Hi im setting up a 21.5 lrp, and i notice that alot of guys have setting with 50 or so timing plus 30 or so turbo,iv read that 60 is the max you should have.i know the lrp has about 27.5 mechanical timing, so how can you put so much timing from the speedy into the motor ?lets say the motor's got 30 then 50 from the speedy plus turbo 30 all up 110. How does the motor handing it ? iv used alot of setting from here and they work really well, id just like to know if any one has a explanation of what is going on.Thanks
#232
#233
hi guys,
just unpacked the new v3. i wanna run modified 4.5T motor. has anyone tried the settings in the default modified programm on the speedo? any changes you guys made? or what settings are you generally running on a 4.5T.
just looked through the thread but its all posts from the v2 and stuff. so i am wondering about the v3.
thx for any help
cheers
thx for any help
cheers
#234
hi guys,
thx for any help
cheers
thx for any help
cheers
#235
I am running 12th scale. Has anyone got a setup running hobbywing 1s with a LRP 4.5 on outdoor track?
#236
I'm not sure i'm following you. I think that is 0 Turbo... right ? if I misunderstood the way parameter work, please enlighten me ! Like I said I was told not to put any, because this would be pointlessly more complex to setup, and not any faster, on such a small track with a straight under 45 feet. But you seem to think I should add some regardless ? Again, not sure what you mean. Thanks still !
increase the boost if u dont want to use turbo..should gain more power..
yes, technically the turbo is off..
u want the highest timing without burning the motor..
#237
Suspended
Great job..i should keep it, very useful
#238
I don't read in this post about adjustable timing (LRP X12 octa)
And is to set-up the motor to different speed controllers
Timming for LRP X12 Oct 6.5 for XERUN?
@cherry2blost
THANKS for this post
Motor used with your Pan Car setup? I put a new one or 213STK?
regards
@cherry2blost
regards
#239
has anyone got a setup for 12th scale 10.5T with boost and that, want to try something but not sure where to start with 1s lipo,
cheers
iam using the HB 1s esc with orca 10.5T
cheers
#240
there are 64 points of timing available
in total - not 64 degrees
