Spur Gear & Pinion
Spur Gear & Pinion
I currently own two drift cars.
1] Yokomo MR4-TC SD SSG Special [Carbon Fibre]
2] Exceed Drift Star 350Z
I have finally got the Yokomo set up how I need it to race with and am now just playing around with the Exceed.
I have installed a 15T combo in the Exceed now and think that I need to change the Spur and Pinion.
The current Gears are broad toothed gears. I'm not to sure what pitch they are, but they are very coarse.
Here's a few pics of the Spur Gear, to give you an idea of what they are:
I'm thinking that a similar combination as my Yokomo set up, would be a good combination for the Exceed too. I have a 72t Spur and 23t pinion @ 48 pitch, which seems to be quite fine in the Yokomo.
Where can I get the replacement spur gears from, to suit the Exceed? It is different to the ones that the Yokomo uses.
Or should I fit a Spur Gear adapter to enable me to use the same Spur Gear as the Yokomo?
Any advice would be appreciated.
Cheers,
Dave
Cheers,
Dave
