Team Associated TC4
i.e. in VTA my local venue everyone basically runs a 4.2 and i have mine geared at 4.17 and have guys constantly asking what i'm geared at because i'm reeling them in on the straight. More times than not if you're 85%+ close on gearing it's not the gearing but car setup & driving resulting in corner speed that will determine what car is "fast".
Ran 2 meetings with it and I like the traction. Only thing i noticed is that ran too loose you get a weird action when using lots of breaks.
we have one corner where we are tight on the inside of the apex and it's a 180 after a straight. so we all have to break hard and enter the corner much slower. I find the car will not turn in under breaking and kinda skids until is gets slow enough or I re apply power.
but the first time I'm running any type of spool
I was running Reedy motors 160-170° and LRP's were into the 200-210° range consistently with no issues at all. On occasion i've pulled them off the track after 6 minute heats @225-230° and saw no loss in performance on the next run.
I posted really not to give hard #'s but to make the mention that if you are running a LRP motor you may not be "overheating" it if the temps are a little higher than you'd expect...
I ran one for a while but stopped because no matter what I did (T-nut, loctite, double nut) to keep it tight it would always loosen. Didn't want to have to check it every run just to be sure i didn't waste a heat with a loose slipper spool.
I had one come loose in a TC5 when I misthreded the Thrust bolt into the aluminum nut stripping it out.
Just use the regular spool, and forget about it ....
As far as LRP motors are concerned, more heat means more waisted energy, which can lower battery voltage considerably when using a 2700mah pack for a 6minute run... I know you guys are using bigger battery packs(7200+mah), but it will put more strain on your equipment(esc,motor,etc...), which will force you to gear down and lose speed.... Cooler is better !!!
I guess I can overgear a bit running a 2700mah pack, but not a 7200mah pack that does not drop off at the end and burns stuff up.... It's all about balance guys. Just the right amount of energy to produce Work, and not too much on either side, pulling(motor) or pushing(battery), to give you a TQ and win...lol...... That's what stock is meant to be !!!
WRONG !!! My Lcd's have been on my Car with a spool for over 7years now with no damage to them at all... The aluminum spool outdrives will wearout, but it lasts long enough for the price.... If you use a steel spool, you will double durability, but the most important part of making your Car durable is your parma wide bumper !!!!
I got the lcd's on my stock Car since 2006, and practiced at FBF and raced at the first 360 track, crashing way more than any pro, and continued Racing at the new 360v2 track until november 2012, and now I had my first meet at Critters this november 3rd with the same Lcd's and aluminum spool in the Car.... 360v2 is reopening mid december,so I hear, and I am sure to get even more runtime on these same drives and spool. I must admit that I don't crash as often as before, but the parma bumper does still require some CA glue... There are many videos of me running/crashing at 360v2 and Critters, where are your videos mopar ??? I don't think you even have one...lol...
I only managed to destroy One lcd drive in my ntc3 when I forgot to shave my axles and ran into the FBF wall at full speed during a qualifier: that's 60+mph in a 1724+gram Car...... The ntc3 steel spool has not been scratched by that incident... They have a video of ntc3 running at FBF too. Again, where is your video mopar??? Do you run nitro ???.
I have a standard locked spool in my car. Broke an LCD joint last week when I grazed the inside of a corner, initally I thought I had just broken the pin, but it was not just the pin but the metal housing of the axle shaft where the first LCD joint holds it together. Those things are a bitch to find these days.
From here on, slipper spool.
