Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 06-29-2011, 10:06 PM
  #9871
Monteman's Avatar
Trader Rating: 16 (100%+)
i have had a few Castle systems though the years an i have never had any issues with them, although im never looking to break any records either. I run them under their limits generally speaking or play with the gearing to pull them back a bit. Comes with the joys of just bashing around, i dont need to be the fastest car out there.
That said, looking at LRP which one am i after. I have completely lost touch with what Associated is doing now electronics wise.
Monteman is offline
Old 07-01-2011, 03:45 PM
  #9872
ao_capone's Avatar
Default gears
Anyone know a good gearing to go with a mamba max pro 7700 and 2s 25c lipos
part number for spur and pinion would be super helpfull
ao_capone is offline
Old 07-01-2011, 06:46 PM
  #9873
For a MM7700 I would start gearing at 8.18fdr(22t pinion/72t spur) to 8.57fdr(21t pinion/72t spur) with rubber tires on a big track. That is a front spool: diffs won't hold up! As for part numbers, go to towerhobbies.com and checkout their pinion and spurs category....
bertrandsv87 is offline
Old 07-02-2011, 10:48 AM
  #9874
ao_capone's Avatar
Thank you very much for responding - i had already ordered a 72t and a 20t witch is 9.00 and geared slightly lower then the 8.57 you said
will that be ok ? i know ill have to just see how the temps are but in theroy that gearing should work right ?
Old 07-02-2011, 01:28 PM
  #9875
ao_capone's Avatar
Does anyone know a digital servo that will fit good in the TC4 with no modification ??
Old 07-02-2011, 01:41 PM
  #9876
A 9.0fdr is a good start, but watch motor and esc temps carefully ! As for servos you can use just about any digital servo: jr z9100s $139.99 is probably the best out there, but you will need to check the manual for the right servo spacer....Remember the losi lcd drives(losa3344) for the front end.....
Old 07-02-2011, 02:10 PM
  #9877
ao_capone's Avatar
ok cool thanks allot
Old 07-07-2011, 08:14 PM
  #9878
Monteman's Avatar
i see my nemesis is back on this Tc4. I couldn't stand the shock mounts on my NTC3, T4, B3 and SC10. I see AE finally made a change to the upper mounts on the TC6 are those Shock bushings (TA Pt # 31250) compatible with the TC4?
Monteman is offline
Old 07-17-2011, 04:46 PM
  #9879
ao_capone's Avatar
i cant post a picture of my tc4 untill i reach a certin number of posts , how many is that ?? im not gonna wait and find out how dumb !! off to find a better forum where i can actualy show people my beloved Tc4 peace out guys
Old 07-18-2011, 08:44 AM
  #9880
Boomer's Avatar
It's fairly standard, actually. I think it's something like 10. Most legit forums don't allow pic posting until the user shows they're a legit user (as opposed to a spam-bot that got around the other verifications) . . .
Boomer is offline
Old 07-18-2011, 02:28 PM
  #9881
I just put a Spektrum S6070 in mine. Low profile style makes extra room to fit the receiver & ESC, but any standard size servo should fit.
Kevin Marcy is offline
Old 07-20-2011, 11:37 AM
  #9882
ao_capone's Avatar
well if its only 10 or so thats not bad i could handle that
Old 08-07-2011, 03:38 PM
  #9883
Bubblehead's Avatar
Default boosted/ non-boosted set-up
I'm looking for a boosted/ non-boosted set-up, can someone help me out?
Bubblehead is offline
Old 08-08-2011, 07:09 AM
  #9884
AM03GT's Avatar
Trader Rating: 13 (100%+)
This part has not changed much since the TC4 Factory Team. That edition the shock bushing was shortened so the shock angle was reduced. Since then the TC5 and TC6 versions are basically the same geometrically except they take a M3 screw instead of a 4-40. That being said yes, they are interchangeable provided you have the M3 screws and enlarge the shock mounting hole in the tower to accept it.
AM03GT is offline
Old 08-09-2011, 11:23 AM
  #9885
Meradin's Avatar
Trader Rating: 19 (100%+)
What are some changes I can make to increase traction in the front end. I am having trouble keeping speed up while making turns. I have t scrub too much speed in order to make the same turns that others are making. I am running 4 degree blocks up front and 1.5 degrees of camber. I have the camber links on the closest hole to get some camber gain in the corner. Is this too much?
Meradin is offline
