Team Associated TC4
#901
Originally posted by punkboy
for the play in the arms, motor shims work well...
#904
Are you sure the pins are bigger? Tony said that the c-hubs from a TC3 would fit the TC4 that wouldnt be possable if the pins were different dia.
#905
i meant to use motor shims for an area where smaller shims are used....as far as the number provided for asc shims...not sure of their size, but if its the shims that come with the kit, then those are to big, im only talkin about maybe .010" of shimming needed...
but, thats not gonna work, cuz he has a different problem...
and, why did u sell ur car losi? didnt like it that much?
#906
"The inner arm hinge pins are now larger-diameter, 40% stronger, and are captured in the arm mounts by pivot balls to provide consistently free, non-binding movement"
#908
Are the outter pins bigger as well tho? If they are the c hubs wont work from one to the other.
#911
so, no tc4 arms on the tc3...
#912
The pins he is having the slop in is the outter pin not the inner. Maybe someone made a mistake and made the holes in the new hubs to match the new inner pin size.
#913
The tc3 and tc4 arms dont interchange. Different hing pin size. The tc4 is quite a bit bigger, 40% bigger I guess. Speaking of arms does anyone know where to get a set of front arms for the tc4? Everyone seems to be sold out or on backorder.
#914
The front input shaft...
wobbles about 1mm. Is this how the new diff cases come or is this a shimming issue?
#915
i noticed about the same amount of play in the one i built...anyone else see this?
