Team Associated TC4
#8221
to set the record straight, I hit the wall the first two times cause the car got really loose in the beginning of the turn but the third time I was going good and I was on the outside so someone could pass and they went high in the first turn and hit me broad side and broke the exact same things as when I hit the wall and that seems unlikely.
#8222
tyre diameter is 65, tell me what pinion you got. cheers.
#8223
No no no...THAT'S not how homework is done.
You tell ME what pinion you come up with. I've given you two blow-by-blow methods, you just have to plug your info in.
I'll tell you if it looks correct. I'll also need to assume you've calculated your current 26mm rollout correctly. It's almost spot-on (26.09mm) if you've got a 23-tooth pinion on there now.
Scottrik
Tell a man the result of the calculation he's set for this heat...TEACH a man how to perform the calculation he's set for EVERY heat he'll ever race PLUS he can help HIS friends learn how!!
Scottrik
#8224
#8225
Originally Posted by E-BUSS
Isn't all this stuff figured out for you already at www.gearchart.com
Plus, being able to make the calculation yourself is MUCH more useful at the track if you find you're off, or are forced to go to a different spur gear size, or... The internet may not be handy, but I've ALWAYS got a calculator in my tool box. And if it dies, a pen and scratchpaper will get me there.
Scottrik
#8226
Originally Posted by Scottrik
Probably...but what's the fun in that? Exercising the upper body (the muscle between your ears) is what keeps you fit and keeps the Alzheimers at bay later in life.
Scottrik
Scottrik
#8227
how good is that site hey,
#8229
hi..does the tower from the tc4(plastic or graphite) make in the tc4ft?
i want a fast reply please!
#8230
#8231
thanks a lot S_fender!!!
#8232
I too ran my TC4 for oval and I hit plenty of boards and never broke a single part. Are you running the stock plastic parts or did you run out and buy the graphite parts kit?
#8233
The only way that a car is not going to break if an impact happens (consistently. . .) is if it's either so solid that it's unbreakable (and then would be so heavy as to be unusable) or so flexible that it absorbs the impacts (and would then be so flexible and flimsy as to be unraceable.)
Impacts break things. Fact of life!
#8234
Well I had my 1st race with the fttc4 this Saturday. And the car is great.
I uesd Baker setup from the roar asphalt natioals.Only thing I had to change was the rear spring from green to silver & front and rear droop.And the car was hooked up.
It alway nice when othere racer, want to driver your car to try it out.
Good job ae cann't wait untill the next race.
