Team Associated TC4
#8101
what would a shorter wheelbase do for the car?
and just to make sure, the number on the rear hingepin is the degrees that that particular mount gives it in toe right?
o and what is the point of switching the triangle, circle or square arm mounts with the x one, ive seen it in some race setups??
#8102
shorter wheelbase generally gives the car more steering... but is as everything else affected by the rest of the setup...
the rear toe-blocks do have the # of degrees printed on them x-2.5 meaning 2.5* rear toe-in
switching the square with the circle changes the toe... the set width of the hinge pin locations are different on the circle and the square... i.e. square+x-3.0= 3.0* rear toe-in... but circle+x-3.0=~1.5* rear toe-in (i may be wrong here on the actual value, never actually tried this before on my cars)
#8103
#8104
Originally Posted by DaveW
FALONSO: .050, 1/16, 5/64, 3/32, will twist every screw on the car. Which TC4 are you running, the tub car or the FT?
#8105
ah ok, i did that stuff, and it turns out i had a 2 bad bearing in the diff cases. thanks for your help!
#8108
F. Alonso: Check the Associated website at http://www.rc10.com for setups and manuals.
Here is the link for the TC4 & FTTC4 manuals: http://www.rc10.com/shusting/Catalog...hub_onroad.htm
#8110
just turn the dials on the shocks, they adjust the ride height
#8112
9 sounds a little bit high to me, but somewhere around 5 mm, like you said sounds good, its a decent general starting point
#8115
