Team Associated TC4
#3737
Yes I have tried the steel ones.. but for one pack only... just too dang heavy.. as far as the advantages of the PAL diff over the IRS one...
1)weight the PAL one is lighter by 1~2grams
2)does not need separate T-nut to build the diff
3)the PAL diff can be shimmedmore than the IRS diff for better gear mesh
4)it comes with very strong teflon blades that are larger in size compared to the corraly ones
5)2 colors Black and Blue
-Dave
-Dave
i hope i can buy them over in asia....not cheaper than US but you dont get your ass spanked at customs....
i reckon by putting lightened steel ones on mine i must of put on atleast 25 grams onto my car....
you say they can be shimmed more....do they come with shims? i need to pick my self up a shim kit from AE but do they come with some?
last thing, any idea on price (in USD?)
#3743
that looks pretty cool
where did you get yours from Dave?
on the other hand, i ran my tc4 tonight (well last night ) and i broke something i would of never imagined of breaking
i was in practise and this n00b put his car down on the straight ready to set off (you just don't do that do you) and as you do you cain it down the straight and i saw his car at the last minute and i got the side of his car trying to dodgey it...pushing all my wheel into my car.....i thought i had totalled the front end but it turned out the sus block had come off (screw been pulled out) and the steering rack split straight in half straight down the middle where that V shape thing is....strange isn't it.
so me and someone else there tried to make the most of it and glued it back together...held up for 3 mins of the 2nd heat until i broke a rear hub carrier and in the other heat the steering rack gave way
has anyone else experienced the steering rack splitting straight down the middle? or am i just a strange english man that can only ever do these ever so weird things i think that 3racing alum steering rack will come in handy after all
enough of the jibberish and off to bed i go (hey its 4am nearly )
#3744
one last thing Dave, i noticed the PAL outdrives are cut to work with D style diff rings..well my AE lightened ones use just circle ones...will i get away with using the circle ones or will i have to get some more D rings?
#3745
Re: PAL diff is now out
Have a look
Have a look
Where can I get one of those? And what size thrust bearings does it use? Or does it use all the stock TC4 plastic diff hardware?
#3746
and how did I get the diff early.. I helped with the testing of the parts... R&D (RACE & DESTROY)
-Dave
#3748
Re: Re: PAL diff is now out
as far as were to get one R/C Champ should be able to order them are monday or there might be a new Speedway PAL dealer in the states soon
-Dave
#3749
The PAL diff uses all of the stock tc3/4 parts..even the D-rings ..
-Dave
-Dave
#3750
Hey Dave,
You think it's possible they PAL will sell those white blades seperatly? If so, I would imagine that they would fit on the normal steel outdrives, correct?
I'm also wondering the price...
