BMI 1/12 conversion/car
#1501
Rick,
It was designed to put the ball stud on top of the chassis cross brace and cut the ball cups down. Some guys like to try different shock locations and angles so we added the holes to the chassis to give more tuning options. It's up to you and your driving style.
Wayne
Wayne
#1502
Oh got my first 1/12th TQ tonight !!
Cheers for all the set-up help guys it really paid off
The car is now dialled and "on the pace" so i'm a happy man.
Biggest and only real difference set-up wise from your suggestion's was to use damper tubes on the rear which i really liked.
#1509
No TQ this week
But i did get an A main win with the local hero's both in attendance and finishing the race
Were on the up !!
Were on the up !!
#1510
Originally Posted by fast-ho-cars
now that it's proven, is the 12A version available?
now that the new kit has been proven,i went ahead and ordered the 2mm carbon fiber to go ahead with production on them.i will have carpet versions ready first due to the fact that the start of carpet season is here.i will follow them up with the A version.
#1511
Way to go Wayne!!!! I heard about your A Main win at the Halloween race. I wish I could have been there to see that amazing finish. See ya in a few weeks!
Rick
Rick
#1512
Thanks Rick!!
I fought radio problems all weekend and changed radios the last qualifier. Had 1 run to get use to it, but it really made a difference. The main was great, we battled 8 minutes and I got lucky to sneak out a win on the last turn passing Dayger and Rice when they were fighting it out. We all ended up with 41 8:01 and were seperated by a few tenths of a second!!. The BMI ran great all weekend. If anyone wants the winning set up let me know, I'll post it.
Wayne
Wayne
#1513
Originally Posted by sg1
Thanks Rick!!
Wayne
Wayne
Great job Wayne!
#1514
Thanks,
Rick
#1515
Carpet High bite:
Front:
CRC soft plaids
1.70", 3 to 3 1/2 mm clearance at nose
Niftech traction out to orange
10 deg uprights
TiCN kingpins
.020 springs with .01" droop
1 deg. camber
shim front and back of top a-arm
servo flat ball studs on top and the backside of servo saver
turnbuckles level from servo saver to stearing block
Back:
CRC white dot
1.78", 3 1/2 to 4mm clearance at stand off location
Niftech traction just in middle of tire
dampening washers with 100 wt. oil
blue springs
30 wt. oil and silver spring center shock with TiCN shock shaft
pod sat level to ground, shock had 1mm droop
.075 Power Push t-plate
batteries 1/8" from all the way forward
Other things:
Parma speed 8 body
Tekin G-11 speedo, charger, and discharge tray
Power Push IB3800's
Team Scream roar epic motor
28-102
apply tire traction 5 minutes before race and scrub on carpet
Front:
CRC soft plaids
10 deg uprights
TiCN kingpins
1 deg. camber
Back:
CRC white dot
blue springs
Other things:
Parma speed 8 body
Power Push IB3800's
28-102
