gt7 on/off swich is broken.....
Hi guys........
i've recently had a disagreement with a another vehicle and broke a on/off swich
How do i fix this? is there a replacement on/off swich harness?
if so how do i fix it?(or replace it)
it never happend to me b4......... PLEASE HELP!!!!!!
thanx
joon k
thanx
joon k
ask your LHS to order you a NOV5600 Switch harness.
yes, it's pretty easy. just get a pointed soldering iron tip and remove the old wire and solder on the new wires.
Hey Guys,
You can also change the switch WITH OUT TAKING THE CASE OFF the ESC. The switch has a small plastic case. Look on the back where the wires come out of the switch. There is a small silver tab, flatten that and untwist the wires. You can then easily slide the case off and unsolder the wires.
Unless the wires broke at the ESC case.
Charlie
Charlie
Originally posted by Charlie
Hey Guys,
Charlie
Hey Guys,
Charlie
I've used his advise and changed the switch multiple times when the inside mechanism stoped working and the unit always stayed on.
If you do decide to solder on from the board, make sure you're very good at soldering. The traces are small and long time with the soldering iron on them will melt the circuit board. Having copper braid or solder wick will also help suck the solder from the trace.
Good luck!
John
