i need some help with this
does the receiver workhttp://www2.towerhobbies.com/cgi-bin...8&I=LXNE05&P=K with this radiohttp://www2.towerhobbies.com/cgi-bin/wti0001p?&W=000604278&I=LXASX2**&P=K
i have anther ques even though noones repled yet. im goin to get a brushlaee motor here is the pic of it........http://www2.towerhobbies.com/cgi-bin...?&I=LXFPW1&P=7 ..........here is the pic of the esc im gettinghttp://www2.towerhobbies.com/cgi-bin...?&I=LXFPW2&P=7 ........i think that u can gear brushless motor anyway u want right? can someone give me a great gear set up i can do? i want to have slow acceleration and high spped, what should i do?
well this is the setup i came up with tell me iff this is good her is what i got.....tell me if this will all work together to ok............http://www2.towerhobbies.com/cgi-bin...8&I=LXZS17&P=K ...
http://www2.towerhobbies.com/cgi-bin...8&I=LXNE04&P=K
http://www2.towerhobbies.com/cgi-bin...I=LXASX2**&P=K
http://www2.towerhobbies.com/cgi-bin...8&I=LXBGE0&P=K
http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=000604278&I=LXGJP9&P=K
&W=000604278&I=LXDDD7&P=K
http://www2.towerhobbies.com/cgi-bin...8&I=LXWL81&P=K
yes all of that should work the only thing you will need are tires and rims
yeah i just picked some out here they arehttp://www2.towerhobbies.com/cgi-bin...8&I=LXM991&P=K
http://www2.towerhobbies.com/cgi-bin...8&I=LXM954&P=K i like these
also what should i gear my brushless motor too i want slow acceleration and high top speeds!!! thanks
i would try some hpi x pattern tires also i have had a alot of sucess with them but the ones u bought will work fine
thanks for all ur help!!!ill look into those tires! like gear a 25 t with umm a 19t..i just got back into rc so i forget how to gear.
so if thats a bad gearing tell me. i also dont want to put alot of stress on my engine.
the tc3 stock comes with a 72 spur so u will have to order a pinion for the motor i would by 3 or 4 pinions to experement with maybe in the 18-24 range if u want top speed
thanks alot ill try that out it sounds like a good gear setup
do u think that i should buy a steel spur gear?
