D8T gearing...
Trader Rating: 25 (100%+)
D8T gearing...
Ive got a D8T and was rebuilding my diffs today. I have a spare Hara D8 diff I keep incase something happens at the track and I need something to keep me going. Well today while rebuilding my diff I happen to notice my stock spur gear that came my truggy is the same size as the Hara D8...a 48T. I matched the D8 and D8T gears up and they are the same size and just to be sure I counted the teeth...both 48. Odd! In my D8T owners manual it states the truggy uses a 50T center spur gear yet my truck came with a 48. And yes I built the truck brand new so this was the gear that came with it in the box from HPI. Anyone else have a 48T come stock with their kit? Anyone know if this is a production change or if HPI made an error when packaging the parts for my truggy?
your running a buggy 48T on yours? With what clutch gear 13T? or did you run a 12? Let me know what you find out with your stock gear. Im curious. debating to track down a 50T or just run with the 48 as it is with a 13T or run the 48T and get a 12T clutch bell
a 48 will not work with the stock clutchbell for the truggy unless you got the wrong spur gear and clutchbell which i just doo not see happening.
Not sure where your getting your info from with that. I have been running a 48T with 13T clutch bell and it works just fine. I am using the stock 13T clutch bell that came in my kit when I bought it new and the spur gear that came in the box is a 48T. I didnt notice it until I rebuilt my diff today. I have ran a gallon and a half on this gearing and have even won races with this set up.
