reciever batt for d8 hara
hey guys, can someone please tell me if a hump batt pack will fit in a d8 hara or do i need a flat pack?
There is a little slot on the side of the box (facing you as you put the battery in) that you can wedge the battery connector into. I run an extension from the rx box to the battery box and leave that under the hump pack. Put the battery on top of it with the connector in the little space close to you....connect the battery and wedge it in there. It's a tight fit with a hump pack....but there is room if you finagle it around.
I prefer to run the Robotronic LIPO which is also a snug fit on the long side...but plenty of room on top of it. Just work with it though and the hump pack WILL fit in there.
im running LRP/Nosram 1700 lipo pack
It's definitely a pain in the rear, but once you get the hang of it....you can do it with your eyes closed. It's a tiny tiny battery box for sure! If you want to check out one of the Robitronic LIPOs for fitment...come see me at PNB. I'll have one in my D8 and my D8T ;-)
