Best Drift Tires? >
Best Drift Tires?
Best Drift Tires?
Old 02-09-2011, 05:38 PM
1320VR4's Avatar
Trader Rating: 15 (100%+)
Default Best Drift Tires?
Instead of going through 1000 pages on the drift thread I figure I'd just ask lol.
what are yall using for drift tires?
I got a set of the yokomo single bands on my 4tec however I'm going to do up a new Mitsu Evo 5 body and wanna get some black work emotion wheels. With that I thought about getting another set of yokomo tires since they work great however they're a bit expensive.
Should I pick up a set of the HPI drift tires? Should I just get some ABS plastic? lol Are the yokomos still the best?
Matt
1320VR4 is offline
Old 02-09-2011, 10:37 PM
sliding_josh's Avatar
Trader Rating: 21 (92%+)
Matt
PM sent!
sliding_josh is offline
Old 02-10-2011, 01:12 AM
DarkSupra's Avatar
Really depends on the surface.
Most people over here use HPI t-drifts (or the R2 replica's) on asphalt or concrete.
DarkSupra is offline
Old 02-10-2011, 07:10 AM
Integra's Avatar
depending on surface, I really liked the HPI tires that came with the RS4 Drift kit, No clue on part # or what they were called, But i know they were HPI and i Know they came with the RS4 drift conversion kits.
Integra is offline
Old 02-10-2011, 07:15 AM
gashuffer's Avatar
Trader Rating: 48 (100%+)
Tamiya DriftTech are great tires. they're 24mm so they won't fit on HPI Wheels unless you don't mind the exposed bead. I run them on HPI's but you have to snap them on though the outside. If you run tons of camber reverse the process.
gashuffer is offline
Old 02-10-2011, 08:16 AM
1320VR4's Avatar
got some poke tuck on that thing!
I drift on carpet, asphalt AND concrete lol. The yokomo's work well on all 3 it seems, carpet I need a little more power though
1320VR4 is offline
Old 02-10-2011, 08:20 AM
gashuffer's Avatar
What's poke tuck!
10.5 is plenty for a rug!
Best of both worlds. Circuit/Street. Enjoy!
+ YouTube Video
+ YouTube Video
Old 02-10-2011, 09:36 AM
1320VR4's Avatar
poke tuck^
What offset wheels should I get? lol. I was thinking about 6mm. I'm currently using Yokomo Rays 57 wheels and they hae like no offset. With the traxxas stampede wider hexes the wheels are just short of fitting 200mm bodies nicely, I figured 6mm would be pretty slick, or maybe a staggerd setup like 3mm front and 6mm rear.
Anyhow anyone know what the offset of the Rays 57 Yokomo wheels even are?
1320VR4 is offline
Old 02-10-2011, 12:32 PM
gashuffer's Avatar
If your running a 190mm body I say 6's. 200mm 9's. My HPI's are 3's but my next set is going to be 6's.
What car are you using? Both Tamiya and HPI make wheel hexes up to 6mills. You can get away with adding spacers but that puts a load on the axles.
Old 02-10-2011, 02:36 PM
1320VR4's Avatar
I'm using a sweet Traxxas 4-tec, remember those? lol
I'll be using 200mm bodies, most of the cool "drift" bodies are 200.
I'm using Stampede hexes which are about 3mm wider than the stock 4tec ones which makes the wheels ALMOST look right on this bod with the rays 57 yokomo wheels.
1320VR4 is offline
Old 02-10-2011, 11:43 PM
how bout some 10mm Speed Way Pal wheels on a 200mm MKll and 350z
Or some 2pc Work Schwert's From Japan
Old 02-11-2011, 10:54 AM
1320VR4's Avatar
why is your wheel SO much wider than your tire? lol
1320VR4 is offline
Old 02-11-2011, 10:56 AM
1320VR4's Avatar
My poopra
Kinda regretting selling my extra Xray, wouldn't have minded 2 cars
1320VR4 is offline
