Side Piece Racing
#157
Has anyone else got the problem where the driveshaft blades foul on the inside part of the outdrive?
They just make contact on the inside edge very close to their mounting screw, almost like the inside edge of the blade slot nearest the pulley needs to be chamfered.
Skiddins
Skiddins
#158
Skiddins
Skiddins
Which drive shaft length?
What arm spacing?
Without any info id guess - your running an XRay with 52mm bones. You'll need to make sure your front width is 2.25mm of shimming on each side.
#160
- ecs
- blades
- left and right chub
- chub collars/bushings
One part that isn't listed, because it is totally optional, is the use of XRay steering blocks (from T2'008/009 or T3/T3'11 -- they are slightly different - and from what I understand the material used on the T3'12 blocks are different yet again). The XRay steering blocks hold up a bit better than the TOP ones. I find that when I run the TOP steering blocks I generally fracture the plastic through the top half of the block by the arm part. On the other hand I cannot remember the last time I broke an XRay steering block -- I replace them at of fear of breaking every time I go to a big race.
#161
I know you've followed the part list so you'll have all the the right stuff:
- ecs
- blades
- ecs
- blades
#162
On the way home from the Halloween Classic.. it was a long, strange trip. Congrats to Larry Fairtrace on hit stock TC win ( TOP Photon equipped with Mira outdrives) . He was closely followed by Mike Haynes to the stripe in stock and strong a-main runs in 13.5 and mod. Many other races also had their Outdrives installed and where showing them off. Thank you again for your support.
I sold out of Nikita Outdrives for XRay T3/T3 spool. Gotta update the web site soon ..
#163
On the way home from the Halloween Classic.. it was a long, strange trip. Congrats to Larry Fairtrace on hit stock Tax win ( TOP Photon equipped with Mira outdrives) . He was closely followed by Mike Haynes to the stripe in stock and strong a-main runs in 13.5 and mod. Many other races also had their Outdrives installed and where showing them off. Thank you again for your support.
Nothing quite like a sidepiece.
#164
Mike,
The Xray (nikita) outdrives are listed as "in stock" on your website, but when I attempt to order via paypal I get a message that the outdrives are "out of stock."
When do you anticipate stock replenishment?
Brian
Brian
