1/12 rec pack????????????
hey guys what rec packs are u using for 1/12
Team EAM
Ive been using the SMC LiFe pack. Not sure of the mah but I think its around 300. At the birds I switched over to a OHP Voltage booster instead to save some weight on a heavy car. Noticed no difference at all in on track performance, lap times or runtime. Simple to install and dont have to worry about charging either.
EA
EA
Power Push LiPo. Had a LiFe pack (not Power Push) go bad despite 0.2 amp charge rate used, just don't want to take another chance. The speed control we use recommends a rec pack instead of a booster due to electronic response time (or something like that) to keep performance optimum.
EA
EA
I am currently using a LRP SXX competition version 2 in my 1:12 and was wondering what is the benefit of adding a rec pack/booster?
Will it cause the ESC to overheat?
Manual states not needed or is this wrong?
Team EAM
EA
Team EAM
Your right it doesnt when I checked either. Email Jerry at [email protected] Tell him I sent you. I think they are 24.00 for the booster. It has a plug that goes into the receiver and then a small red and black wire that solder to the battery post on the speedo. It comes with a switch and you just turn that one switch on and thats it. It provides 5.5 volts to the electronics.
EA
EA
www.ohiohobbyplus.com The novak one is huge and looks like a birds nest. While I have never had a Novak or had a failure I have raced with several that have had failures. The OHP one is tiny and easy to install.
EA
EA
Has anybody tried the tq booster..... .. what's the diff between the one an ea is talking bout.... also supposlly what thwe down fall to the boosters are
i use this one, works perfectly. little shrinkwrap around it and 2 cables to the esc and you are ready to go
http://www.hobbycity.com/hobbycity/s...dProduct=11784
this is the Novak: http://www.nexusracing.com/product_i...29c1daaa63f932
one more thing i might add...its a bit cheaper than Novak is....
