Ko Propo VFS-1 ESC
#1381
What KO model is the Tamiya Volac Esc? Thanks!!!
#1382
VFS-1 Pro
#1383
Just ordered the VFS-1 J value set off of the Ko Propo site... figured that for 150 bucks it wasn't going to get much better than that! I guess I better get reading on the 1300+ post backlog here before I fry the thing!!
#1384
you won't regret your vfs. its one of the most incredible pieces of equipment you can buy for your car. i have the hara 2.1 and there is no doubt about it.
#1385
First question, even before the thing arrives: Is there any advantage to running a full Ko Propo setup (ESC/Radio/Servo)? My radio will be replaced at some point in the near future, so the Helios is definitely an option... albeit a pricy one!
#1386
no advantage... it's just how well you drive...
the Helios is definately a good radio to upgrade to.
#1387
where the manuel for the setting adaptor
case i don't know if ld means load the speedo or load the adaptor
#1388
#1389
Originally Posted by V12
From what I have heard until today the Competition still have a temp cutoff but itīs higher than the Pro version. It is possible removing the cutoff completetly at least KO can this do for you. But I think then you could burn your VFS-1 when the termal load is too high.
#1390
Twister Profile Settings
Hi guys,
I've got a VFS with the handheld programmer. I was wondering if anyone could share the profile settings of the Twister, I'd like to see what the differences are with the factory settings compared to a Twister.
Thanks (Salamat)
Thanks (Salamat)
#1391
LD means to load a "saved" profile that was previously saved on the handheld. there are 3 memory slots in handheld adapter for saving profiles.
#1392
Originally Posted by Piyo Piyo
Thanks V12. . Better run with temp cutoff and miss one heat than buying a new speedo.
#1393
VFS-1 Pro Comp in the UK?
Is the latest version of the VFS-1 actually available officially in the UK? I've looked at the sites of all the big suppliers and I haven't seen a single carbon-cased KO-brand speedo.
All I've seen are old-model Hara Twisters and the Yokomo Masami and Rayspeed models (these are carbon case, right?).
Would I HAVE to grey import to get a Pro Comp with Setting Adaptor??? Big shame if I would...
#1394
The Yokomo Masami and Rayspeed models both are available as old and new version.
#1395
to the ko propo team can you help i have a PS 2015 Fet servo and have stripped the gears where can i get replayment gears, i have tried shopatron but i am not sure which ones to get for this servo, please help
cheers
judge
ko propo racer
cheers
judge
ko propo racer
