Ko Propo VFS-1 ESC
#436
John, I have a Q2 and a VFS-1 right now and for carpet at least I prefer the VFS-1, and here's why. I run a one-way with some roll throttle, and with the Q2's variable frequency, I've noticed that the amount of roll isn't consistent because the Q2 is switching frequencies. It's made the car feel a bit inconsistent. I also like the "feel" of the VFS-1's bottom end more than the Q2's, but I need to try a new profile on the Q2 (even though the manual says to use #5 for stock, talking to some folkes at AE they say to use 4, so I have to try it). And don't be afraid of the settings, it's really easy to adjust if you have either the hand held programmer or the software.
#437
I did feel a difference when I went to profile 4 from 5. I didn't like it.
Tim
#438
Originally posted by asw7576
my friend got this thing, awesome size! smaller than his receiver.
but he ran into overheat problem in 5min - 8t modified race. he had to stop and go few times
#439
Originally posted by JohnMatrix
If you had a choice would recommend this esc over the Q2?
This thing scares me to much because of all the settings.
id recommend the VFS-1 over the QC2 just because of the flexibility it will give you. sometimes you'll hit that sweet spot gearing on your motor.. but just want a tad more punch.... the VFS-1 will let you do that. QC-2 will only give you the option of profile 4 and 5. (when i did have one, i used profile 4 for stock and it was decent)...
but with the VFS-1... drop the drive frequencies and you can customize the punch and rip in all the different phases of your throttle motion.
btw.. i had my VFS-1 in my EvoIV when i raced up there.
- Chris
#440
Thanks for the info guys.
Now I buy the Speed Control and than I need to get the Hand held programmer and or the software?
Whats the cost on ether of those?
Thanks guys.
Thanks guys.
#441
How do you reset VFS-1 pro to factory setting? My mate told me that the stock setting from the facotory is good enough for 23T motor. I have the handheld programmer.
Thanks in advance.
Dennis
Thanks in advance.
Dennis
#442
Thanks in advance.
Dennis
Thanks in advance.
Dennis
This setting is stock (pretty sure, havent used the darn thing in like 4 months), and the other setting will need changing if you have messed with those.
#443
Thanks guys.
Thanks guys.
you only need one or the other. software will require a laptop tho (dont know if you wanna lug that to the track). handheld/esc combo runs about $220 at speedtech rc
http://64.23.108.110/speedtechrc/218.html
- chris
#445
Originally posted by linger
Hey Robert,
If I buy the Tamiya version of the KO speedo....will KO do the warrantee repair on those if needed?
-Ling
Hey Robert,
-Ling
#446
Can i use the single ko shokti diode with a 12x3 motor or will i have to get the double diode and what does the condenser do i couldnt see it mentioned in any other posts.
#448
#450
Should be a single. I bought a double and it is quite a bit thicker. Wish I knew that I only needed singles for stock, wouldn't have bought the double then.
