Ko Propo VFS-1 ESC
#2341
Moving to LIPO
Apologies if this has been discussed before. We are moving to LIPOs. Anything I need to be wary of in terms of settings for the the VFS-1 C2? And does the VFS-1 C2 have the capabilituy to recognise the LIPO has discharged itself to the minimum voltage (of fthe top of my head 6.0v), or do I need to buy one of those voltage checking circuit boards that does this?
#2342
#2343
VFS-1 help.
Hello I have a message for Heibiki or KO STAFF,cuz you seems to know your gear...
I have the Twister 2,1 which is the VFS-1 pro? Or Pro Comp?
And I checked the settings on the KO site for touring 27T.
The setting start like
#1= 2
# 2= 3
#3=3
what I mean is the values are very low. I will give you my freq's and you will understand why I ask. I do not want to burn up my speedo. I have heard too low a number very fast but high risk of burning out. I have also heard no more than one value at a time. If I wanted to use the given throttle profile on the KO site it is a difference of more than 30 values!!! Am I reading wrong? I thought maybe it is 2 is 20 or 3 30 but when it gets to 6 it can't be 60? I hope you know what I mean. I just want to know what is the maximum from my profile I have given that I can change. All the profiles I have read are under ten for each value. as you can see mine are over 25.
Also which default should I use from the site? VFS-1 ,VFS-1 Pro etc.
My Throttle profile is as follows when I got it.
All Sellect= 35
#1 = 37
#2 =37
#3=37
#4 =35
#5=33
#6=31
#7=28
#8=28
Thanks for the help. Merry Christmas!!
#1= 2
# 2= 3
#3=3
All Sellect= 35
#1 = 37
#2 =37
#3=37
#4 =35
#5=33
#6=31
#7=28
#8=28
#2344
C2
Hebiki,
Thank for the help on the vfs but apparantely I am getting the C2 now as the price for a pro is just a slight difference....
Now I have to re read everything again just to understand how I should go about setting the c2 for my race setup... excuse for my ignorance ...kinda slow on theories... but thank for your help again.
I will can on you if I get stuck half the way.
Woof Wooof
Woof Wooof
#2346
The software difference is the amplifier tuning and the Throttle response has changed in the software setting from Punch (VFS-1 Pro) to drag brake setting (VFS-1 Pro C2).
#2347
#1= 2
# 2= 3
#3=3
All Sellect= 35
#1 = 37
#2 =37
#3=37
#4 =35
#5=33
#6=31
#7=28
#8=28
#1= 2
# 2= 3
#3=3
All Sellect= 35
#1 = 37
#2 =37
#3=37
#4 =35
#5=33
#6=31
#7=28
#8=28
#2348
The only difference in the hardware is the case. VFS-1 Pro has a black case, VFS-1 PRO C2 has the carbon looking case.
#2349
Hebiki
Hebiki ,
you have PM
you have PM
#2350
What the difference between the vfs-1 and vfs-2?
#2352
so would that still be just as good with mabuchi/johnson motors?
#2354
Heibiki
What all select # should I start with when using the stock technical profile off the KO site?
#2355
Thanks for getting back to me. The profile I started with the 30's I have been using for stock 27T. It is running fine, Can I use the lower numbers without burning up my motor or ESC? like 1, 2 , 3 etc. etc.?
i usually start the first two stages at the same number then lower it from there so i dont get any initial wheel spin. wherever you start, you should be fine. just adjust according to traction conditions at your track. (more traction = lower starting freq.)
