Ko Propo VFS-1 ESC
#1487
Originally Posted by FUK_WRX
KO Staff: Is it possible to get the VFS speedo repaired? I blew my 2.1 yesterday it got that hot that it destroyed some a portion of the case and desoldered all the wires i love this speedo was a pity you think its not worht fixing?
#1488
-Robert
#1489
Hello,
I just purchased the Helios, the VFS-1 Pro Comp. Value pack, and a PDS-2123FET servo. (7.2V)
I needed to know how to hook up the blue wire to the speed control, and I was told that I may need to set the BEC at 3.0v, rather than 2.3v. The servo came with, what looks like, the other end of the blue wire, and it looks as though all I need to do is solder that wire to the speedo somewhere, but I dont see where.
I would think that just letting the blue wire from the servo hang, would just make it not perform as well as if it were attached.
Would I be better off just going to another servo that does not involve this blue wire?
Thanks in advance for your help,
Robbie Dodge
Robbie Dodge
#1490
Originally Posted by KO PROPO Staff
Sounds like it probably is not repairable. You could always send it in and see if it is. You say 2.1, must be a Hara edition. If so, you will either have to send it back to Hot Bodies or KO Japan for repairs.
-Robert
-Robert
#1491
Originally Posted by punkboy
Hello,
Robbie Dodge
Robbie Dodge
The servo will not power up until you connect the blue wire. Connect the blue wire to the positive side of the battery on the esc. Make sure that you use the choke that came with the servo, or you will damage the servo.
-Robert
#1492
Thats what it looks like, even the case was kinda melted exposing some electrical components up front. I dont get how it happened i turned my speedo on and tried it up and down the straight, and then i went to grid my car and all at a sudden took off on its own n tipped on its top there it was in full throttle then white smoke started coming out of the ESC what do you think would be the cause of this?
#1493
hello, ko pro--- i have novak receiver and lrp esc,airtronics servo
i am thinking of getting a ex-10 helio transmitter and servo....
will i have to change my receiver and esc.to make it work ??????????????
thanks for looking
thanks for looking
#1494
thanks for looking
thanks for looking
#1495
You will have to change your receiver, but the radio comes with one.??
#1496
the receiver comes with the radio ?
#1497
last question, will a kr 301f receiver work ?
#1498
In the Super HSR (High Response 3CH mode) or the normal mode. Should not be used with the Advanced HSR mode (High Response 2CH mode) [Factory Default].
#1499
thanks for the quick responces
#1500
Robbie-
-Robert
-Robert
Thanks again for your help!
